Flail Mower Let's talk flail mowers
   / Let's talk flail mowers #5,561
Curiosity, does anyone make an 8-10' flail, 3 point or pull type, with a decent size gear box that's intended to be more than a stalk chopper? I go from an 8N to a 4020, so I have a big jump in HP. I'd prefer to buy a flail the 4020 could run for the extra width. I have 23 acres of currently unused pasture I'm maintaining. Current mower is a Schulte FX-210 10' rotary.
Rears or Vrisimo come to mind. Both are quality products and well built for daily use. As you get more capability as far as shredding, HP demands per foot of width increase quite a bit.
   / Let's talk flail mowers #5,564
Start looking for a used JD290 (7' cut) or a used JD390 (8' cut) if you want used.
New in that size would be a Vrisimo, they occasionally have rebuilt used units at times so it would be best to contact them in California directly.
They sell direct to the buyer as well so that may be an option if new iron is a must.
   / Let's talk flail mowers #5,565
Peruzzo, got mine from The Iowa guys PTO Hydraulic Offset Flail Mowers -- Iowa Farm Equipment My Supper Bull is 8' wide, 1,700lbs & ended up around $7k. When running into yucca or wrist sized woody brush my 40hp machine starts running out of steam but the flail is still going strong (according to the ratings & my seat of the pants measurments). It mows fields & pastures well too giving a pretty decent cut. In theory I could mow a lawn with it too, but I nor people I mow for actually have one.
I think the 8ns were only rated to lift 1k or so on the 3pt. At 1,700lbs the Super Bull or anything similar will be almost double that. You could probably spin it but it would be slow going. Lifting will be the pain point. My L4060 couldn't actually lift the flail on the pallet with forks on the loader when I got it. You could probably run it if you always left the roller on the ground.
The quick hitch adapter was pretty crappy & probably for CAT2 instead if CAT1. The scraper for the roller kept getting jammed up with cuttings & got removed. Other than that it's been bulletproof for the year I've used it so far. Ignore the fact its crooked, that the crappy Kubota valve letting the sidelink leak down.
   / Let's talk flail mowers #5,566
You might have missed that he's upgrading to a John Deere 4020?
   / Let's talk flail mowers #5,567
I interpreted that as he was possibly going to be trading the mower between the machines.
   / Let's talk flail mowers #5,568
I love my JD 390. I too maintain About 30 access of hillside pastures. It cuts much better than muy BH 3210, though i can't cut down 4" trees with the flail.
   / Let's talk flail mowers #5,569
I have both, but width and HP differences prevent me from sharing many implements between the two machines. I致e slowly been moving to buying bigger implements for the 4020
Electric Utility Cart (A56857)
Electric Utility...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59575)
2017 VOLVO VNL64T...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
7PC. PALLET OF 2" X 4" X 240" SQ TUBING (A52708)
7PC. PALLET OF 2"...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
