Let's see your welds...
/ Let's see your welds... #161
I was going to ask if they were AR. Question, shouldn't they be going the other way? With the curl of the bucket? Or are you expecting the dirt to fill the voids, and protect the bucket?
We don't have the ability to roll the curve in the AR at my shop so I figured exactly what you said that the dirt will fill the voids and act a the wear surface
/ Let's see your welds... #162
Here is a lift for my Bi/Fold aircraft door. Good welders are in high demand in my part of the country.
/ Let's see your welds... #163
Can't remember every adding wear strips to a bucket, but probably have. I have spent days hard facing clam buckets though. I always just did it the way the operator wanted it. Back in my drilling days, I seen more knock down fights over what angle to weld the teeth on! I'd just stand back until someone would hold it for me.:laughing:
/ Let's see your welds... #164
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=296979"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=296984"/>
Holy garage door opener! Good looking welds
/ Let's see your welds... #165
Those are some big drills shield. I know exactly what your talking about some guys want dot hard facing some want "x's" some want circles some want grids and if you start welding the "wrong" pattern they yell and scream and question your mothers virtue
I'm an advanced beginner/beginning intermediate MIG welder of farm stuff that's in position. I have a Lincoln SP 170 and here is a typical weld of mine. The photo looks funny because it appears the weld stops prematurely but that is an optical illusion. The metal has an arced curved surface to it and I welded the flat surfaces and it looks right.
/ Let's see your welds... #169
Heres a couple tig welds using the positioner.
/ Let's see your welds... #172
A t-joint of 1/4 aluminum made with a Millermatic 210 with spool gun.
/ Let's see your welds... #174
If you weld a Pepsi can to a Coke can, do they break each other down like dissimilar metals? Perhaps you need to weld a piece of a RC Cola can in-between to prevent electrolisis?
/ Let's see your welds... #178
I tried the cans with our dynasty. HF, I thing 5 amps, and triangle wave with pulse set to not deliver much heat. Now granted, we didn't have a small enough tungsten or filler, but I still kept burning through.
If that was done with a conventional gig, m
y hats off to you.
Are you sure those aren't solid slugs of aluminum with. A can body over it???:)
/ Let's see your welds... #179
Welded thoes with an old Miller syncrowave 300. Have welded others with syncrowave 250's and Lincoln square wave 225.
It can be done with a normal cup and a 1/16 electrode (prefer 2% to pure as you need to keep the tip sharp vs the normal ball for aluminum) but its a bit easyer with a .040" 2% electrode and a gas lense.
Never tried it with any of the inverter machines I have but I bet they would do it.
/ Let's see your welds... #180
