Let's see your Kubota
   / Let's see your Kubota #361
Yea that would be an IH 686 with an M&W turbo putting out 106hp.
I have always wonted a IH886 cab tractor come real close to buying a 1086 about a month ago. But I bought a 2004 NH TL100 instead,maybe wife will let me get a forth tractor later on,lol.
   / Let's see your Kubota #362
foreman Etexas
Have you ever entered/exited an IHC 86 series with a cab as that seemed very awkward to me. Several yrs back my friend had a 986 that he asked me to plow with for him. After a few hrs I unhooked his 986 and attached my 4255. IMHO my 4255 rode much smoother than the 986 with cab in front of rear axle. I told my friend I would not drive his 986 again. SCV control levers are nearly on the floor of cab which isn't convenient for someone who is 6'4'' tall plus I didn't like the LH gear shift lever.
   / Let's see your Kubota #363
I have been In but never have operated one. I had a 805 Belarus cab tractor for several years and it can't be as bad as it was. I mainly won't one cause I like the looks of it and when I was growing up that's the tractor always had toys of guess just been fond of the IH since a youngin...
   / Let's see your Kubota #364
L3800 with the help of Brian at fit right hydraulics my baby is about done. The top and tilt should be in any time.
   / Let's see your Kubota #365
My L3800 with the help of Brian at fit right hydraulics my baby is almost done. Top and tilt should be in soon.
   / Let's see your Kubota #366
Wow!!!!! You have quite the set up their.
   / Let's see your Kubota #367
Here is my Bota as of yesterday! I just brought it home sunday from doing work with it at my cousins step fathers farm, lets just say what that little beast could do, left my cousin and his stepfather speechless! He didn't want me to take it back home. Well it now has the mowing deck on it for another season of mowing. Shes got about 214 hours her!
   / Let's see your Kubota #368
I first got the KX41 stuck. Though I would dig it out with the B3200, it got stuck so thought out came the mini B4200 to the rescue. It got stuck too. It was quite cold and the snow was crystalized and would not pack. Still learning how to operate the Excavator and eventually it pulled its self free and then freed the other two. Killed 3 hours. In all likely hood if I had a second person the B4200 could have pulled the B3200 out but when alone you have to put the tractor in gear and get it pulling while you jump off and get on the other one, but by that time the first tractor spun itselft stuck.
   / Let's see your Kubota #369
David.
Just part of owning tractor. ;)
   / Let's see your Kubota #370
Wow, I know most tractor guys are pretty creative, buy I would urge you to either be more creative or less so. Let's assume for the moment that this scheme worked. How are you going to stop them? Throw the one you are on in neutral, jump off and go catch the other one. Except the one in neutral is now chasing you because it is pulled by the one you need to catch. Can you mount the front one from behind it or do you need to get in front of that churning back wheel? Either way, one slip on that crusty snow that would not pack and you are under either one tractor or maybe both. Now they stop when they hit a tree, rock, or ditch. You're a mangled mess on the ground. There is only one positive outcome to this attempt and hundreds of negative outcomes. Better to leave them stuck and live to fight another day.
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2015 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A58214)
2015 TROXEL 150...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
500 Gallon Fuel...
