Lets See Your DIY Tow Behind Landplane
   / Lets See Your DIY Tow Behind Landplane #31
Here's the one i made. 4 foot wide to use behind the B6100
   / Lets See Your DIY Tow Behind Landplane #32
I'm impressed by the projects and number of people who made their own land planes. I feel like a sissy for buying one, lol
   / Lets See Your DIY Tow Behind Landplane #33
Built about 2010, still going strong! The sides were a 9/16" table top, the cross members are 4x4 square tubing, the angle iron that holds the blades is 4x7x1/2.
All in all, this thing is heavy, and does a nice job behind a 70 HP tractor!
David from jax
   / Lets See Your DIY Tow Behind Landplane #34
David from jax
I like the multiple holes for the 3pt lift arms. Do you use them to achieve crown?
   / Lets See Your DIY Tow Behind Landplane #35
No, (although they could be)they were added as options for height of the lift arms. They really come in handy when I drop it in a low spot and come back later with a different tractor!
The crown is determined by the angled blades and can be slightly modified by adjusting the top link. That is one reason I don't understand why people buy (or build) landplanes with blades angled opposite of each other.
You do have to pay attention to this feature when going back and forth on a roadway, as the amount that it crowns isn't much, and easy to remove or crown in the wrong direction!
David from jax
   / Lets See Your DIY Tow Behind Landplane #36
Some people use land planes to crown driveways. Some use them to get surfaces absolutely smooth. Opposite angles work well to get a really flat surface. Perhaps the ideal tool would have one adjustable blade so you could level or crown.
   / Lets See Your DIY Tow Behind Landplane #37
This probably isn't precisely what you were looking for, but here is what I built to maintain a 1/2 mile road. The tail wheel helps keep the crown intact.
The tail wheel on my road drag helps keep the crown intact
   / Lets See Your DIY Tow Behind Landplane #38
I built this one about 15 years ago. It's 65" wide and weighs about 700 lbs. I can add 4 concrete weights totaling 180 lbs to bring it up to almost 900 lbs. The side runners were made from an old school lunch table with steel seats. I welded 2 half of the 8' bench together, thus the 48" length and filled with sand.There is 1/4" plate on the bottom of the runners.
The blades are adjustable. Here in the desert the soil is either loose blow sand or rock hard caliche. I have no gravel roads. The doing sand, the front blade is adjusted to flat and the rear is adjusted to rear down to smooth the sand. When in caliche, the front blade is adjusted to a 1" cut and the rear adjusted to the condition. The concrete weights are 45 lbs each and when in caliche are added to the front to enhance cutting. In sand the weights are not used or placed evenly.
The 3 point connection works with my T&T. I can pull it forward to let the plane just float or push it back if I only want the back blade to smooth.
The blades rotate on 1" bolts acting as an axle.
   / Lets See Your DIY Tow Behind Landplane #39
View attachment 809447View attachment 809448View attachment 809449View attachment 809450View attachment 809451View attachment 809452
Interesting design - I like your blade height adjustment !!
gg
   / Lets See Your DIY Tow Behind Landplane #40
The longer the plane is, the smoother and more level the surface. Just like when working with wood, the longer the plane, the straighter the surface.
The smoother the surface is the faster the vehicles drive...the faster the vehicles drive the more gravel gets pushed out of the turns. It's a slippery slope
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2013 Chevrolet Equinox LTZ AWD SUV (A56859)
2013 Chevrolet...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
23013 (A55787)
23013 (A55787)
2013 International Derrick Digger Truck (A55973)
2013 International...
