muddstopper
cost is going to add up very fast on this splitter. I do think you are going about the hyd all wrong. Instead of looking for a single big flow pump, I think I would use a double pump setup. This would allow you to pump the 60gpm at high pressure and power, and then another 60gpm at a low pressure for speed. Using a unloader valve you can dump one pump back to tank as soon as your low pressure setting is reached. This would be a good way to run high splitting tonnage and high speed with such a large cyl. Not sure what you plan on splitting, but I can split a 30in round on my spliitter, 6 ways in one pass and I am just using a 5in bore cyl. Unless you plan on making some sort of cookie cutter wedge, your cyl is way overkill for just about any size wood. I will also agree with others, re-sawing long splits is a real pain and more work than sawing to length and then splitting. Also even with a 6way wedge, if you have large dia wood, you would need to do a lot of resplitting of you splits. a 24in dia log split 6 ways will still give you 6 splits that are 12 inches wide.
