Lets build some QA "ExtendoForks"
/ Lets build some QA "ExtendoForks" #1
Bansil
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
So I had to move the hot tub about 600 ft.
Grabbed the QA plate I made to move the old chicken coop and ground off the angle I had tacked onto it.
I then tacked it to table to use as a fixture
Then added 3 pc of 2'x2'x1/4"x8' wall tubing I had in an old Trooper.
I had to make a taller brace for the middle fork due to flexing of the QA plate, since it had no support
Then I grabbed 2 pcs of 1-1/4x1-1/4x3/16 wall 5 ft long to add "adjustable extensions to forks"
worked great
Worked great, used several strategically placed straps, we have some more big things to move and then I will use it for brush until I build a grapple
You can see how I used the straps to lock everything in tubing to QA plate and then a strap between them two and another one to tension everything tight, it never moved
/ Lets build some QA "ExtendoForks" #2
That's impressive. It looks like the tractor should tip forward.
I lifted one end of an 8 person tub last year and pushed it into the final position. No way my 48" forks would have lifted the whole thing.
There were several times I extended the BH and even had it extended out on the ground to the uphill side when I turned, it never felt unstable
It was supposed to be 684 lbs. empty+ 160 lbs. for left over water = ~850 lbs.
With the bucket + 48" forks + a 8 ft pallet all 30" from pivot point...tractor wouldn't budge it, so I lost the buckets wt. the heavy azz 8x8 pallet and the very heavy2x3x48 forks.
Tractor would only pick the hot tub up parallel with the ground, when we got to the new deck, my friend pulled up on the front strap he said maybe 20#s and I easily lifted it another foot with hydraulics, tilted down and set it on the deck.
Thanks!
/ Lets build some QA "ExtendoForks" #6
Did you learn to weld as a trade, or is this just a hobby you've taken the time to really practice?
Ive been a machinist for 30 years, been building race trucks/offroad vehicles for 40 years, Yada, yada....
This was lowrider, 16 point cage, 3/4 elliptic rear suspension, welded rear etc. Built in the backyard for cheap...2009 ride of the month with backyard low budget build ...it was a build for planetisuzoo to represent the web site
I like building stuff....been piddling with this...My cycle karts build
And now the tractor let's me keep building stuff ;)
For me it's fun to think of a project, design it and build it, I hate when people say "you can't do that" or "that won't work" haters going to hate 😛
/ Lets build some QA "ExtendoForks" #8
Cool stuff you built (y) You got talent
Quick pics for those who don't want to follow blind links >
Good call, thanks!
The vale picture is a real car, I am building a replica using 17" Honda CB90 wheels and a 6.5hp engine.
Here are a few pics of my building the rear end and engine mount
And working on the cage when it's snowing 🤪
F@#$ photoexploitingbucket
/ Lets build some QA "ExtendoForks" #10
Well your typical hot tub isnt wider than 8' so as long as your forks are on the heavy side 48in forks would prob lift it. I know mine did.
/ Lets build some QA "ExtendoForks" #11
The large tub I helped a neighbor with didn't have much underneath frame-wise, so I didn't even try to totally lift it. I had visions of the 48" forks coming up through the bottom of the actual fiberglass tub.
Exactly why I needed the 8ft+ no way to pick it up w/o the forks damaging it.
EZ Trail 3400 (A64126)
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
LS MT225E (A64126)
LS MT225E (A64126)
2022 Bobcat E42 (A64126)
2022 Bobcat E42...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2023 Bobcat T86 (A64126)
2023 Bobcat T86...
