Let it snow
/ Let it snow #1
jpalasek
Florida / MD
Kubota ZD331 Toolcat 5600
Just bought a 84 in snow blade. Dealer delivered it yesterday. We only get snow about 6 times a year. The Bobcat dealer had the blade for 2 years because we have had little or no snow here the last 2 years. Got a great deal.. $2,000.00 .
I have some hills where i will be plowing and think I might need some weight in the back. What is best to use for weight. Sand Bags?
/ Let it snow #2
"Let it snow" ...easy there,just might get couple northeasters. ;)
Weight..try metal drum full of cement..rod thru cement near bottom for 3pth connection,top place piece metal in cement connect top hitch.
Try search,think someone while back posted pictures.
/ Let it snow #3
I'm using sandbags. 10-50lb bags to start. If I need more their easy enough to add or take off. Unless you get very heavy (wet) snow and deep dumps you probably won't need any ballast. I live in very steep terrain and only need it when I have the 843 lb. blower on the front and an blowing steep drives.
DEWFPO
/ Let it snow #4
SNOW! That is one of those 4 letter words my dad told me not to use.
/ Let it snow #5
I use 9, 70# landscape blocks in the TC bed for ballast.
The TC bed has some prepunched square holes that you can use stove bolts with in order to make a quick bedliner out of four 2x4's. For the floor of the bed I used a rubberized "stall pad" that can be had from about any ranch/home/feed store. The bed will then accept the keystone landscaping blocks in a tightly-packed pattern leaving you about 14"+ at the very end of the bed for tire chains, hi-lift jack and/or toaster oven. Actually I then covered the whole thing with some OSB just to keep the bed from filling with snow. I also used a small rectange of OSB to protect the inside of the front of the box.
I like weight and I like chains..all the time...except for "the other nine months"..although they can occasionally come in handy then as well.
/ Let it snow
Thanks for all your help. Sorry for using the 4 letter word. I would be happy if it sits all winter. Looks like Spudgunner might get snow today..
/ Let it snow #7
I just want it to snow, I know i said it, so I can try out my new 169D yanmar in it and plow the driveway and the road too.:D I plan to use my rear blade. I cant wait!
/ Let it snow #8
Nope, thank goodness... but I could see the enemy decending the slopes above us. I got the TC back from BC today. Got charged about $275 for a hyd fluid change (with both filters). I didn't think that was too bad; however, one of the filters (presumably the tall one) cost like $47. Ouch.
Now to reload the ballast...
New/Unused Landhonor Quick Attach Tree Puller (A61166)
New/Unused...
Kubota L3901HST
Kubota L3901HST
Lifts (A61567)
Lifts (A61567)
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
(INOP) YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A62129)
(INOP) YANMAR...
Pallet of Anchor Shackles (A61166)
Pallet of Anchor...
