lessons learned in life
/ lessons learned in life #1
baraboo wisconsin
none as of now
i may only be 19 but i have learned a lot the hard way
when lifting things always lift straight up and hook above the weight - trip to e.r. 5 stiches in my lip a painful lip and a pair of broken glasses
when working on tmr mixers watch out for the knives on the augers
when cutting with a torch watch your ears also slag in ear - trip to e.r. and multiple trips to doctor and having a skin graft done on my ear drum
when grinding there is no such thing as to much eye protection
when drilling dont hold your work you never know when the bit will break - trip to e.r. and pita because fingernail was basicly shattered
watch out in the cement trowel aisle in hardware stores - 7 stiches
when changing shovels on a cultivator or working with plow bolts dont try to keep the bolt from spinning with your hand - trip to e.r. 5 stiches
i may remember more
brett
/ lessons learned in life #2
You need to stop going to the ER and just grab some paper towels and some duct tape with you from now on and keep on working:D
I learned real quick that welding upside down is not fun, a lot more head protection was found in a hurry before I continued:)
And that holding the bolt from spinning thing is something everyone has to try to realize our hands are not as strong as a steel tool:rolleyes:
Have fun
/ lessons learned in life #4
brettliddicoat said:
watch out in the cement trowel aisle in hardware stores - 7 stitches
Both my kids managed to flip shopping carts while I had one hand on the cart and was looking the other way. They were three years old at the time. I'm having trouble imagining exactly how a 19 year old gets hurt in the store.
Nowadays, I use a lot more safety equipment (all that I can) than I did at your age. Don't forget to protect your hearing. That one creeps up on you later in life.
So far my worst lapses in judgment have been with fuel and or fire.
/ lessons learned in life #7
Don't spit into the wind.
Wrestling with a pig just makes the pig mad and you get dirty.. and you still probably never catch the pig.
soundguy
/ lessons learned in life #8
Watch out for front license plates bent forward (from going through the carwash too many times). Trip to the ER for stitches on July 4th a couple years back.
Thumbs and Big Toes should not be "buddy taped" if you think they are broken. They have different pivot axis. Trip to ER, then Foot surgeon after Big toe didn't get better after 8 weeks.
Always wear a hat when welding, torch'ing, or grinding. No ER trips (yet), but have done a toll on my scalp
When welding without sleeves, wear sunscreen. I almost never wear sleeves when welding. But, after several really bad sunburns on my arms from the weld, I have started to carry sunscreen in my welding box.
NEVER sit with legs crossed (indian style) when weldinding/torching while wearing shorts. I have WAY too many pairs of undies with burn holes in them :eek:
Knee pads are nice when working on hard surfaces, UNLESS you are welding/torching. then, they act like nice funnels to bring all of the spawls next to your skin.
You'd think after all of these lessons I'd be at least a little bit smarter :eek:
well i was about 13 when the cement trowel thing happened i was walking down the aisle not paying attention to what was hanging off the shelf and a trowel was sticking out of the shelf i brushed my arm against it didnt even notice untill i felt someting running down my arm (blood)
yea the plow bolt i thought if i put enough pressure on it since they work like carrage bolts that it would grab it did- my finger
yea i have done the sunburn more than once i finally bought some leather capes keeps you cooler and prevents sunburns and hot metal burns
burnt scalp a lot also when welding and cutting also found a way to clear out your sinuses if when your cutting with the torch if you get some of those sparks up your nose it will clear em out good
im shure i will think of more
brett
/ lessons learned in life #10
Just remembered another couple.
When the wind catches a piece of tin roof'ing that's not fastened (was building a shed), don't try to catch it. Couple of stitches later, I have a nice scar on my wrist.
When starting a fire with gas, if it's already smoldering, pour the gas into a cup BEFORE putting it on the fire. Caught a perfectly good 1 gallon chainsaw gas can on fire.
/ lessons learned in life #11
When chopping down a tree, check all the trees around you for beehives and wasp nests.:eek:
Got banged up real bad in my haste to get away. After that, I think the bees all fell down laughing. I ended up limping slowly to the house. Stings, cuts and bruises healed well but the ribs took months.
/ lessons learned in life #12
don't lean fluorescent light bulbs up against a wall. One time i tripped and put my hand all the way through the middle of a 6 ft long fluorescent bulb and pulled it out in time before the top piece came crashing down. Luckily no cuts or anything except broken glass.
/ lessons learned in life #13
Arguing with a politician is like getting into a peeing contest with a skunk. Even if you win no one smells worth **** when it's over.
/ lessons learned in life #14
Threads like these are why I am not an EMPIRCIST...:D
Charles Sanders Peirce had the right IDEAS...;)
/ lessons learned in life #16
Always carry material on your leeward side. That way you can let go before you get blown over.
/ lessons learned in life #17
After 21 years in Naval Aviation... Gravity is a powerfull force.
mark
/ lessons learned in life #18
certain jobs should not be done when you are angry. Always use the right tool for the job. Never use a framing hammer instead of a tack hammer after arguing with a future exwife.
/ lessons learned in life #19
New one for today, wear gloves when working on projects in the shop. My old "cheapy sears" drill press was binding up. Pushed up hard on the handle to try and move it around. Plastic knob shattered and the rod gouged a chunk out of my palm. The ER dug the plastic pieces out of my hand and gave me 6 stiches. The Dr. had to comment that a new drill press would have been cheaper.
/ lessons learned in life #20
Now I have an excuse to upgrade my old cheapie sears drill press :D
Hope you don't mind if I share this with my wife to get approval for such drill press. Of course, I'll have to leave out the part about just wearing gloves :)
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
1997 HUBBLER BROS. LOGGING TRAILER (A67714)
1997 HUBBLER BROS...
2016 Nissan Pathfinder 4X4 SUV (A66738)
2016 Nissan...
2005 STERLING LT9500 SERIES HYDROVAC (A67714)
2005 STERLING...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2014 BRENNER 210 BBL CRUDE TRAILER W/ PUMP (A67714)
2014 BRENNER 210...
