Lens shade number?
/ Lens shade number? #1
BufordBoone
Platinum Member
Tuscaloosa, Al
Kubota L5740 & M7060
I have a #10 auto darkening lens (forget the model but was recommended in threads on this forum) that I use in my hood (white in color, possbily called a Pipeliner?)
It is not a variable so is always a #10. I've never had any eye discomfort after welding with this lens.
Yesterday my right eye was sore and red. Just the right, left was normal. My wife asked me if I had been welding. Of course I had. Only difference was I grabbed the thickest scrap I had and turned the machine up to about 150 amps.
I doubt my eye discomfort was caused by welding, mainly because it is only one eye. But it gives me a good chance to ask?
What number lens shad do you guys use?
Do you change shades based on the amps you are using?
Thanks.
/ Lens shade number? #5
#10 should be ok, if the lens is too dark, you won't be able to see the weld.. how bright did the welding seem?.
/ Lens shade number? #6
^ +1 check for scratches, i'd replace it with another shade 10. It doesn't take much of a scratch to let in enough to damage your eyes.
/ Lens shade number? #7
Sometimes you can just get eye fatigue from squinting or straining. One eye or both. Maybe try a cheater lens, Reading glasses or Bi-focal. Works for most folks. But if it's one of those Gold coated lenses it is probably scratched.
All good recommendations, thanks. No scratches that I can see. I wear reading glasses instead of using a "cheater" lens.
Puddle didn't seem much brighter than normal.
/ Lens shade number? #9
I use a #10 lens setting on my 3M Speedglas auto dark, I was using a #11 but I couldn't see the weld puddle very well.
/ Lens shade number? #10
If you do not want to spend the money of a new lens then at least flip the one over that you are using. Then if the other eye gets sore it might be a clue :)
/ Lens shade number? #11
There really is not enough information given to give you any meaningful advice as you never said what you were using to weld.
IF you were welding with stick rod, then by all means #10 shade is plenty and should not have bothered your eyes, assuming you did not get arc flash from early starts or something.
I prefer #11 though for welding with Flux-Core.
For bare-metal wire with no flux, I prefer #12 or #13.
It also depends on what you are welding. Stainless steel, or aluminum is going to have more reflected light so you would want a darker shade.
My suggestion is to go out and buy a better welding hood with adjustable lenses. They are only $40 now, and the phototronics in a welding hood do get weaker over time. It is entirely possibly that the speed in which your older helmet is changing once an arc is struck, could be a lot less time then when it was new. We are only talking 1/100th of a second here, but if you do the math on that, if you make 100 arc strikes in a afternoon, that is like getting 1 second of unprotected weld flash. I do not know what your helmet is getting, but that could be the cause.
I would just get a new helmet, it would be worth it.
I have got welding flash WAYYYYYYYYYYYYY too many times, and it is miserable...like sand fried up on a cook stove being thrown into your eyes: hot and gritty.
Actually, I believe I have received meaningful advice, despite my failure to provide sufficient info. Your advice, however, is appreciated. I see that I need to either get some other lenses or one that is adjustable.
I was welding with stick rod on mild steel.
The lens I use is an ArcOne S240-10. I think it is a good lens, even though it is not variable shade. I use it with a protective glass lens in front of it. The protective lenses are less than $5 and easily replaced. Better hoods with adjustable lenses are only $40? ****, I failed on researching that one. I'll know next time.
I'm really lucky in that I don't think I've ever been flashed. Main reason I wondered about this was that the highest I'd welded before was about 110 amps. I wondered if going up to 150 amps meant I needed a darker lens. Thanks to all the replies, I know it doesn't.
I love this place!
/ Lens shade number? #13
Buford, I bought this one to teach my eldest grandson, I ended up liking it better than my $400 Jackson -
Antra AH7-86- Auto Darkening Welding Helmet Huge Viewing Size 3.86X3.5" Wide Shade Range 4/5-9/9-13 Great for TIG MIG/MAG MMA Plasma, Grinding, Solar-Lithium Dual Power, 6+1 Extra lens covers …: Amazon.com: Industrial & Scientific
A bit more than $40, but I'd already tried one of HF's hoods - ended up tossing that in the trash, never could get it to work no matter HOW much light I stored it in... Steve
/ Lens shade number? #14
HF's hoods use non-rechargeable Lithium batteries, and once they die, they have to be replaced by someone skilled in electronics. the photocells don't charge the battery, they just help it along as long as the battery is good. I don't know why the misconception that the batteries get charged started, as they may explode, as they are not supposed to be charged..
/ Lens shade number? #15
Try checking the gasket behind the clear lens and in front of the dark lens i like to use 2 gaskets 1 in front of the clear lens and 1 behind the clear lens i used a pipeliner helmet for years.
/ Lens shade number? #16
X2 on this. Most of the time flash burn when welding is caused by a light leak from a bad /improperly seated gasket. I always used clear lens followed by gasket then another clear lens. Always check for light leak after changing clear lens. A bright flash light dragged around the perimeter from the outside while looking thru from the back works fine. If you see any light the gasket is leaking. Best to do it in a dark to semi-dark spot so that even a tiny bit of light is visible. It only takes very small light leak to burn your eyes when you are welding for several hours. Slight redness is first indication of a leaking hood.
By the way, you can weld all day with a #8 without getting flash burned. Your eyes may get a bit strained from squinting in the light but not burned. Same thing with used too dark of a lens, it strains the eyes.
Contrary to what most people think, when welding in a dark space, use a darker lens. When welding outside, use a lighter lens. I used to use a #10 when welding inside a dark building but switch out to a #9 when outside. The reason for this is that your pupils are dilated more when in the dark so you need a darker lens to block out more of the light especially when you first light up. Outside in the sun, your pupils are constricted so you dont need as dark of a filter.
/ Lens shade number? #17
The shade you need is what need to be able to see the puddle clearly without glare from the arc. If you can’t see you can’t weld good. Darker doesn’t give you more protection. Too light and glare washes out the puddle. Some welders can weld with any helmet. Some are very particular. Finding what works best for you is the trick. My friend who is a world class welder gave me beautiful Jackson professional helmet. Never could get comfortable with it no matter what I tried.
Ordered, BukitCase. Thanks for the recommendation.
/ Lens shade number? #20
Back flash from your environment.
Yup, I’d definitely look at reflective surfaces overhead and behind. I’ve got a shop rag attached to mine that flips down over the back. The main reason is sun interference but it can help with reflection issues as well.
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
Eagle Line 3pt 5' Box Blade (A64911)
Eagle Line 3pt 5'...
7 foot bucket (A64194)
2014 International 4300 DuraStar Crew Cab Knapheide Utility Flatbed Truck (A68183)
2014 International...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
