Leinbach PHD mounting & down-pressure questions
   / Leinbach PHD mounting & down-pressure questions #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
I've had a Leinbach PHD on longterm loan from a friend & just agreed to fork over cash (getting a great deal, but the friend might be borrowing it back on occasion) for it so it will be mine permanently. I'm not sure if its a L7300, L7200, or L7200jr (update: probably a L7200, as a see the hole for the guide rod & looking at the color, which might not mean much & size of the hoop), but it more or less fits on my Kubota L3200.
Need to get a photo of it on my tractor here at some point.
Does anybody know if there is a hydraulic down pressure kit available for Leinbach PHDs? I couldn't see any on Leinbach's website or on ETA. If not, anybody know of a generic kit I might be able to adapt? Or would I just be better off on welding on a couple shafts on the spine above the gearbox & finding some weights to hang on them?
Question 2... What is the optimal way to setup a PHD? I fiddled with all 3 toplink holes & the various holes along the PHD spine trying to get the most height possible, but no matter what combo I tried, the tip of the auger would frequently end up barely dragging on the ground. I'm assuming the lowest toplink hole & the hole in the spine that resulted in the hoop being as vertical as possible when the 3pt was all the way up would result in the most lift. Or are my calculations off? I've thought about trying to modify it slightly and raise the hoop an inch or 2, but wanted to see if anybody else had any bright ideas (and to see if there was a down pressure kit that might be messed up by the mods) first. It doesn't drag much, mostly when driving over less than smooth ground, but enough to make me at least think about doing something.
The 9" augur that comes with it is extremely sturdy & has meaty carbide teeth on it. It probably does well in rocks, but frequently stalls out a foot or 2 down when it hits some of our clay. I ended up getting a cheap 4" or 6" augur which does its best to corkscrew into the same clay. Makes for decent pilot holes. I might get new thinner sharper teeth or a more aggresive spiral tip for the 9" if it's possible. But it has me thinking about down-pressure as well.
Advice?
   / Leinbach PHD mounting & down-pressure questions #2
I think the first hole from the tractor side is the highest setting and then connecting to the bottom hole at your tractors top link will give you all the lift possible. I know on some tractors it will still only barely clear the ground regardless of what you do.
As for down pressure, I haven't heard of anything that will give you down pressure on a 3 ph PHD, but that isn't to say that there isn't something out there. I have heard of folks hanging some weight on the end to increase the drilling force and it seems to help.
   / Leinbach PHD mounting & down-pressure questions #3
Fallon,
Leinbach's in East Bend North Carolina is going out of business. If you want ANYTHING, call them ASAP and see if they still have something squirreled away. Sometimes they have something put in an out of the way place.
I have a Leinbach's 1912 one bottom plow that I finally decided to get the colter and gauge wheel for. I had it shipped to me two weeks ago, and found out Leinbachs is going out of business this week.
Farmall Cub
   / Leinbach PHD mounting & down-pressure questions #5
Do you have contact info for them? Nothing I could find on their website.
Down-pressure kits for a 3pt PHD usually look like 6818-Danuser Down Force Kit For J20/80 Series 3 point PTO Auger good video describing how it works too. Price is almost double what I've seen for some others though.
Fallon, here's the last known good phone number I had as of two weeks ago: Phone #: 336-699-3000 - Ask for Charles.
I checked their website. It is now down, so apparently the shutdown is underway.
Good luck trying to get your parts.
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A51039)
2014 Dodge Ram...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
