Leinbach equipment
/ Leinbach equipment #1
gunmaker
nw nj
jd 1025r / x750
Looking for info on the quality and durability of Leinbach equipment. The price seems right, but I'm not familiar with the line.
/ Leinbach equipment #2
I had a Leinbach 5' rear blade. Worked fine for me, seemed to be very well made. I sold it because it did not fit with a quick hitch.
/ Leinbach equipment #3
I bought one of their Post Hole Diggers from Marshall Machinery over in Honesdale, Pa. a few years back. Seems well made and strong. I've no complaints but then again, I have nothing else to compare it to. It's dug many holes without a problem (except operator error) and you can use the boom as a lift too. No matter whose brand you buy, have a 36" pipe wrench on hand to back it out when it gets stuck. Best advice is to go slow & steady.
/ Leinbach equipment #4
decent stuff for the homeowner about on par with KK
/ Leinbach equipment #5
I have a Box Blade and PHD and both have been great pieces of equpment.
/ Leinbach equipment #6
rdln said:
decent stuff the homeowner about on par with KK
Due to the fact that I share equipment between 40 HP/ 47 hp/ and 60 hp tractors, I try to get implements that fit equally well, yet will hold up to the 60 hp/7800 lb bigger tractor. I've owned and trashed a few KK implements over the years. (rear blade, mower, disc) I still own a 72" KK tiller. The tiller is in line with Leinbach equipment. Beyond that, I'd say Leinbach is even a step or two above KK in stregnth and reliability for the most part.
I have a 72" pulverizer and a post hole digger from Leinbach. Had a disc for a couple years. Good stuff for the dollar.
/ Leinbach equipment #7
They have several lines for phd, I have the heavier one, bot both are good. They are heavier than KK by quite a margin if you look at them.
I have a friend that has had both a speeco and a KK both worn out and gone during the time that I have had my Linebach, and we do approximatley the same amount of work.
He now has a Linebach and he is very satisfied as well.
Just my 0.02.
/ Leinbach equipment #8
Timely post! I was just looking at one of their disc harrows. My New Holland dealer caries them. This guy does not sale equipment that he considers junk. So with that said, it should serve you well. However, I did not buy a leinback. Dealer also sales Tufline. He just happened to have a hardly used Tufline harrow sitting on his lot. He said the quality was better, so I went with it, despite a little rust that I'll be removing somethime this week.
Thanks all...sounds like the way too go. I was a bit afraid to put out the $ without any idea of quality.
/ Leinbach equipment #10
I have a 7' Leinbach rake, nice heacy unit. It has many miles on it and it's held up well.
/ Leinbach equipment #11
I have exactly the same things from them. I wouldn't confuse them with being the best, strongest thing available, but they are decent for the money. Most of the line is far above some of the stuff from other companies being passed off as "quality" that I consider junk.
/ Leinbach equipment #12
They're sorta "high end economy". Good enough for most folks needs.
I wadded up the top link portion of the 3-point hitch on the pulverizer. (abuse) It spent the better part of 2 full days hitting rocks and a few stumps while hanging on the back of a 60 hp tractor that was in too high a gear. (5-6mph, 60 hp tractor w/ 45 hp rated implement.
Hit or miss on the opinion of the post hole digger.
That'll do !
NEW HOLLAND 355 FEED MILL (A64277)
NEW HOLLAND 355...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
