Legacy xl runs VERY Hot!!
   / Legacy xl runs VERY Hot!! #1
bebop86
NJ
Used the tractor to mow some high grass yesterday for a few hours- Today upon start up the engine is running VERY HOT!!- I shut it off- checked everywhere for clogging nothing found- What would caused the engine 25 hp?? Kohler to run so hot and what should I look for thanks so much!! Actually the unit is the Massy 2925 which is the same as the Legacy -it is about 7=8 years okd and always maintained-- thanks again
   / Legacy xl runs VERY Hot!! #2
Did you ever find out what is causing this. I have a 2003 2925 and it started running hot this summer. Cannot figure out the cause.
   / Legacy xl runs VERY Hot!! #3
Did either of you figure this out? My '03 2925 is running hot now for a couple of years. Now it is shutting down when it gets hot and will not start until it cools for about an hour. I think this new problem might be the ignition modules. I did check for vacum in the fuel tank and it still would not start after opening the cap.
   / Legacy xl runs VERY Hot!! #4
Mouse nest in the cooling fins under the engine cowling?
2013 BRENNER 250BBL TRI-AXLE ALUMINUM TANK TRAILER (A53843)
2013 BRENNER...
1-Pallet  20X100 6-MIL Poly Sheeting Rolls (A53117)
1-Pallet 20X100...
2013 ISUZU NPR STAKE BODY TRUCK (A54313)
2013 ISUZU NPR...
Bad Boy Pro Z Zero Turn Mower (A53117)
Bad Boy Pro Z Zero...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
