Legacy xl runs VERY Hot!!
   / Legacy xl runs VERY Hot!! #1
bebop86
NJ
Used the tractor to mow some high grass yesterday for a few hours- Today upon start up the engine is running VERY HOT!!- I shut it off- checked everywhere for clogging nothing found- What would caused the engine 25 hp?? Kohler to run so hot and what should I look for thanks so much!! Actually the unit is the Massy 2925 which is the same as the Legacy -it is about 7=8 years okd and always maintained-- thanks again
   / Legacy xl runs VERY Hot!! #2
Did you ever find out what is causing this. I have a 2003 2925 and it started running hot this summer. Cannot figure out the cause.
   / Legacy xl runs VERY Hot!! #3
Did either of you figure this out? My '03 2925 is running hot now for a couple of years. Now it is shutting down when it gets hot and will not start until it cools for about an hour. I think this new problem might be the ignition modules. I did check for vacum in the fuel tank and it still would not start after opening the cap.
   / Legacy xl runs VERY Hot!! #4
Mouse nest in the cooling fins under the engine cowling?
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
backhoe attachment for full size skid steer (A53421)
backhoe attachment...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
STORAGE FEES (A54607)
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
