LED
Billrog
Armstrong, British Columbia
Kioti 2610, 580 SuperM Case Backhoe
Stuck a 45 W LED on the back of my tractor & since the wires were handy right next to the original power supply I plugged them in to come on with my headlights. I only use the tractor to plow my own place with a 3 point plow so it can stay on with the headlights and not bother anyone. If it snows I'll get to try it out.
Threw 4 of those on my ROPS, 2 forward & 2 back. They are great, 10x better than headlights.
They look pretty good !! I tried to find them with a quick google but didn't. Maybe you could give us a brand name. Thanks.
/ LED
TY airbiscuit for your post that's the reason I bought mine but I did make a mistake in my post by saying 45 instead of 48 w.
Looks good. My only comment would be you might want to get it higher to have less shadows from the implement, especially if you raise it up and then back up quickly to then plow forward. Should be fairly easy to add a pole or bar to raise it if needed.
Mine are Tuff-LED I believe, off Amazon. Ton of clones out there, they even copy the bit in the product description about there being a ton of counterfeits & only buy from the real Tuff LED. No clue if the knockoffs are actually any worse or not. Often they come out of the same factory.
I put four LED lights on my Deere 2305 a few weeks ago because I only had the factory headlight. What a huge difference they make in visibility and being able to see!
I bought these from Texas Liberty LED.
2 X 2 Cube
2 X 2 Cube
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
2013 Mack CXU613 T/A Day Cab Truck Tractor (A64556)
2013 Mack CXU613...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
