LED workshop lighting - the saga continues
   / LED workshop lighting - the saga continues #11
The conversion kits I used did require replacement of the tombstones on one side of the fixtures. I have since learned that there are LED bulbs available that do not require replacement of the tombstones. Although replacing the tombstones and cutting out the ballasts was no big deal, I would certainly go for the simplest solution if I was to do it again.
Well in another part of the shop I had two troffer style fixtures w/ 3@ 4' fluorescent bulbs (T12) per fixture and two ballasts per fixture that failed.
I bought 8 of the 4' LED bulbs (~$150) and they came with the replacement tombstones. This was excellent because two of the old tombstones had cracked. I've put 6 of the bulbs in the 2 fixtures. They are showing about 800 lumens at reading chair level, as bright as a well lit supermarket.
I wrote to Hyperikon and requested 4 more tombstones, which they are sending. I'll probably pull 2 LED bulbs out and use them elsewhere.
   / LED workshop lighting - the saga continues #14
Any pictures?
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
More info coming soon! (A49346)
More info coming...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2022 Adams CLC-1013 Conveyor - New (A51039)
2022 Adams...
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
