LED work lights
/ LED work lights #1
Bluesteel
Illinois
LS MT 357HC
I installed 4 new LED work lights. What a huge difference. I stayed with the oval design to look like factory. They are 1350 lumens each. I got them from Surplus Center for around $225 for all 4 shipped. The brand is Buyers which makes some very nice products.
/ LED work lights #2
I just purchase an LED area light ( ONE LIGHT ) that lights up an area 400 feet, so you could read a book in the field at night. And it's only 150 watts. LED is the only way to go.
/ LED work lights #3
Links to where you guys bought your LED lights, please?
/ LED work lights #5
Looks good, I like that.
/ LED work lights #7
Looks good! I love my LED light bar but I do think your install looks cleaner.
/ LED work lights
Well, I don't know. Yours looks pretty good. I don't have a welder yet so I didn't want to get into fabricating a bracket. I've got to get me a welder. Yours probably puts out more lumens. 2 of mine combined are 2700. They are nice lights for the money. Aluminum housing with SS bracket. Came with 3/8" SS bolts but I went down to 5/16" SS so I didn't have to drill out the hole in the factory bracket. Thought that may create a rust spot by compromising the paint. I did repaint the front brackets a while back.
Hey AaronS, when you get a chance can you send me a pic of the side of your hood where it meets the grey cowling in front of the windshield? Is there any adjustment on the hood you know of? Mine hood is a little out at the bottom on left side compared to the right. Seems like the hood doesn't contact the rubber seal between the hood and cowling very much. Just curious. Thanks.
/ LED work lights #9
Yes I'll take a pic when I get a chance. As for my light bracket, it's all bolted, no welding involved.
/ LED work lights
I think it was George had the welded one. Looks good all the same. Thanks.
/ LED work lights #12
I was thinking a light bar for the P7010C. Now I'm thinking of going with 6" oval LED lights too.
CT
/ LED work lights #13
The one advantage I see to a light bar setup like mine vs. separate lights at the corners is the light bar, being centrally located is less apt to catch on brush. I caught a tree limb with the right from light bracket when brush-hogging close to a woods last summer. Luckily it didn't cause any damage but it easily could have.
/ LED work lights #14
How many modifications did you need to do to install them? I have the factory lights and was looking to do something like you have. Thanks
/ LED work lights #15
I'm an old retired guy. The only time I work the tractor at night is to keep ahead of major snow storms with my little JD 3038E. I got five LED lights with little draw but bright light and mounted them on a 1 by 4 board... Four forward one back... Spliced the wires together on the board and ran one pair down to the existing AUX plug - then bungeed the board to the top of the ROPS. It lights up everything, doesn't overpower the tractor electric and is easy to put on when needed. I use the tractor in a forest a lot and a permanent set of lights would get knocked off regularly by limbs. It makes me feel almost in control out in the middle of a heavy, snow-filled forest plowing at midnight - with the snow just pouring down. Seeing all around you is comforting.
/ LED work lights #16
Lot's of discussions on mounting LED lights.
A number of us have mounted the single lights on neodymium magnets.
I like cup magnets with a #1/4-20 thread and about 100 lbs of pull example https://www.magnet4sale.com/cup-magnets-neodymium-w-threaded-stud-112-lb-holding-power/ .
This lets me stick it on the ROPS and move it around, easily rotate to use as a spot light or easily take it off and use it elsewhere.
/edit - I've tried the strong magnets with 400lb pull but they are overkill for a $15 LED light.
/ LED work lights #17
I mounted a led bar with 4 90 pound rated magnets. I haven’t had a need to use them yet but I don’t think strength will be an issue. I paid about $10 for a 6 pack. The main reason I used magnets is the light bar in the lawnmower is in my way getting on and off the mower and I wanted to be able to remove it. I mounted some pods in the back of my truck with zip ties. They have been hit twice and broke the zip ties without damaging my lights. IMG_1645.JPG
/ LED work lights #18
Wow! Old thread.
Here is my more recent thread on the subject
https://www.tractorbynet.com/forums/ls-tractor-owning-operating/402937-lights-cab-tractor.html
And here is a video of my new lights with links in the description.
LSXR4145C Tractor - Added better lights and preparing for cold weather - YouTube
I am very pleased with the outcome. No modifications to the tractor other than removing the stock lights.
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
Enlon Electric Drive Wood Laythe  (A62679)
Enlon Electric...
Grizzly Bear Statue (A65583)
Grizzly Bear...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
621B PAN 300Hrs on Engine 3406 Offsite Danville VA Everything Works (A62613)
621B PAN 300Hrs on...
