LED Lights
/ LED Lights #61
I've got 2 of the 27w flood lights from tractorhelp.com and love them. They light up a decent sized area but aren't trying to throw light into the next county. I like the floods as they throw the light in a wider area where as the spot lights are pretty focused from my understanding. I went with the 27W lights as I didn't figure that they would be "too bright" and they aren't. The sure light up the area, but it's just about right. Make sense?
/ LED Lights #62
That's kinda what I was thinking. 2 flood lights forward and 1 rearward should put plenty of light where you need it.
/ LED Lights #63
Hey Guys i'm new to the forum but i Mounted two Rigid Industries Dually Wide angle D2's (Made in USA) on my M8540
These things are 27 watts but produce almost twice the light output as a standard 55 watt halogen. They do produce heat as others have mentioned in this post. I mounted them using a RAM mounts so i can easily adjust them or face one backwards and one forwards. My 35 watt kubota rear work like looks like a flashlight compared to these things. I should really set up my SLR to take some comparison shots of the Tractor head lights compared to the Rigid. at approximately 100 yards distance from tree line to my barn. with the LEDS on i light up an area about 50 -100 yards wide at the tree line depending on placement. Switching the tractors high beams on only makes a miniscule difference in the light being thrown out.
These lights are not cheap but besides being made in USA rigid also includes a full wiring harness with OE type waterproof connectors a lighted switch and relay. I typically only use the stock headlights when traveling public roads
Dually D2s (Set of two)
View attachment 292304 View attachment 292296 View attachment 292297 View attachment 292303
How did you wire them? I assume you have a toggle switch so that you can use them indenpently from the factory headlights?
/ LED Lights #64
That was really easy. Rigid supplies a complete wiring harness with relay, Lighted water resistant switch and waterproof automotive style connectors at the light. I installed the switch and relay in and under the plastic trim panel that covers up the area between the 3pt control and the rear valves. I ran the wire down and under the platform and tied into the accessory harness on the right hand side of the motor. I believe this harness is normally used for 3rd function valve on the loader. I believe the regular duallys do not included a relay just a switch and harness because the amperage draw is so low. I'll see if i can find a picture of the switch.
Dave
/ LED Lights #65
Dave
I wonder why they would even need a relay. The lights don't draw many amps? Maybe the switch is small? :confused:
/ LED Lights #66
Dave
Could I splice into wire that run the ligths on the fender and put a switch where I can turn it on and off as long as the factory lights are on?
/ LED Lights #67
I ordered the 27W LED Round Flood lights from LEDstore on ebay. They were delivered from the west ccoast to WV in a few days and the lights looked really good. I ran down some plastic washers for the swivel points of the lights. I put 2 facing forward and 2 facing rear. I made brackets out of unistrut and welded some bolt ears on. I picked up the power from the factory work light circuit. I used panel mount toggle switches and drilled and mounted them in the light bracket. I turned them on after dark and all I can say is WOW. I had a few questions for LEDstores and they responded quickly and to my satisfaction so my next light purchase will again be from them. Ledstores :thumbsup::thumbsup:
/ LED Lights #68
I used them too. Very pleased with delivery, product and performance
/ LED Lights #69
Most likely it's a throw back to the age of high power halogen lights that are going to be installed on the front of a vehicle. You just simply attach the main fused power wire directly to the battery.
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2025 MB27 27in Mixing Bucket Skid Steer Attachment (A61572)
2025 MB27 27in...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
