led lights tying into factory lights? Kubota L4330
   / led lights tying into factory lights? Kubota L4330 #11
If you wire an LED backwards it it a short circuit. They conduct when forward biased, and glow when reverse biased. Be sure to observe polarity.
I'll mention that to him. Thanks. :thumbsup:
   / led lights tying into factory lights? Kubota L4330 #12
Well, I'll be the first to point out I was wrong. Disregard what I wrote above.
   / led lights tying into factory lights? Kubota L4330 #13
tractor stuff 003.jpgtractor stuff 002.jpgHere is my nothing fancy installation. Two 27 watt LED floods looking forward and two toward the rear. All are fed from the 10 amp work light circuit.
   / led lights tying into factory lights? Kubota L4330 #14
Notforhire said:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=284938"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=284937"/>Here is my nothing fancy installation. Two 27 watt LED floods looking forward and two toward the rear. All are fed from the 10 amp work light circuit.
How do they work at night?
   / led lights tying into factory lights? Kubota L4330 #15
They seem to give plenty of light. They are floods, so I don't think they have the reach of regular headlamps, but should do well for snow removal ect. I had used regular driving lights on my last tractor, by disconnecting the headlights and tapping into that circuit. It worked well, but required more time and effort than using the work light feed. I don't do much night work, and the LEDs made for a easy hookup. Total cost was about $140 w/ brackets and wiring.
   / led lights tying into factory lights? Kubota L4330 #16
I bought 2 12v Par-36 55 watts ATV/Truck/RV Utility Rubber Work Lamps (around 15$ each) and installed it on brackets inside the ROPS so it's not in the way when going in the woods. I connected it with the connectors that are located under the seat. I already had the Kubota 35 watts worklignt installed and connected at the same place. Since all 3 cables goes to the sams fuse that is 10 amps, I changed it for a 15 amps (35 watts + 55 watts + 55 watts = 145 watts / 12 volts = 12 amps). A 10 amps fuse is too tight for those 3 lights at the time but, since it only draw 12 amps when they are all on , it won't damage the wires. I have to admit that I never try letting them on for a very long period of time (hours). Hope it will help you.
   / led lights tying into factory lights? Kubota L4330 #17
Can you put up a picture of inside ROPS lights - I want to do the same but I am really not sure about the brackets? Did you make them or buy them?
   / led lights tying into factory lights? Kubota L4330 #18
There must be a rule or something, they all do it. My Kubota and MF both are the same. On my Kubota since I have a cab with worklights I just unpluged the harness from the bulbs so I could use the running lights.
My MF has a fancy setup so you can't use the worklights while the 4 ways are on so I have to use the grill mounted lights on the road at night. Have to almost drag the bucket or raise it silly high.
Go for it. Stupid kubota engineers mounted M6800 headlights low, below the FEL bucket. The plastec lenses also faded milk jug white. I added two lights higher, inside the FEL frame hood guard. I clipped one wire in the factory harness that went to the factory high beam filament and wired it to the new lights. Now the low-high switch operates the factory low (dim) beam, or my high and bright beam which shine over the FEL bucket instead of into the bucket back. The work light circuit goes to the rear work light.
Do it.
   / led lights tying into factory lights? Kubota L4330 #19
Funny all the LED posts now. Back in the old days of 2008 when I did my ROPS work lights, LEDs were way more expensive, and there weren't anywhere near the number of options that are available now. Because I used Halogens, my factory rear work light wire still sits unused.
I wired in 2 relays off the battery (one for each pair of front & rear lights), then installed Kubota L39 worklight dash switches to make it look factory installed. If I were to ever want to add LEDs to that setup, there's enough power to run about 20,000 lumens worth of LEDs up on the ROPS. :laughing:
   / led lights tying into factory lights? Kubota L4330 #20
Take a look at my light mount photo, in my earlier post. Just flip the light over and they will be inside the ROPS.
Bill
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
Spreader Attachment (A56859)
Spreader...
1607 (A57192)
1607 (A57192)
18' X 20' STORAGE GARAGE TYPE CARPORT BUILDING (A52708)
18' X 20' STORAGE...
