LED light questions.
/ LED light questions. #71
I have two more and I was thinking of doing that just in front of the ones that are there, but I wasn't sure if I would like all the light coming from behind me. I thought I would turn the ones I have around and try it first. If I don't like them there I will have to come up with a way of mounting them on the front of the Sun Shade, I think just under the front lip.
I have 4 total on my ROPS, two facing forward. I have no issues with them behind and above me. Kind of helps light up the sides a bit too. Sure beats lights mounted on the hood that are always partially blocked by the FEL.
/ LED light questions. #72
Where are you guys sourcing the fuse block from? I want to put that in first and then I will add lights and other stuff.
/ LED light questions. #73
Blue Seas has a great line of waterproof circuit panels and other electrical devices for Marine and RV applications. No relay build in but easily added.
A little less waterproof is the Painless Wiring Unit called the Circuit Boss. There two units have relays build in just add power and accessories.
Make sure you fuse the power source wires and as close to,the power source as possible.
/ LED light questions. #74
I just got one off amazon. Not waterproof, but it's under the dash. Lasted 1 winter so far. =)
/ LED light questions. #77
XFaxman - Thanks thats exactly what I was looking for. I like the line of rockers they have as well. They look too big to shoe horn on to the dash. First things first.
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
1667 (A57192)
1667 (A57192)
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2007 Ford E350 (A55973)
2007 Ford E350...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
