LED Light Bar?
/ LED Light Bar? #1
thirk454
Rockwall, TX
LS XR4145HC
Has anyone done a swap out of the cab dual spot lights for a single 30in or 50in LED light bar?
/ LED Light Bar? #2
Haven't considered going to a single bar but I have considered going for swapping them for 10 or 12in ones on each side. I just don't know that its worth my while, I don't do much work after dark.
/ LED Light Bar? #3
I have not swapped them but have added LED light bars F&R. I made brackets mounted to the mirror mount arms to hold them. Also added flashing strobes F&R and an LED electronic strobe on top. Reflective tape added to the sides too. I like to be seen at night, dusk, or dawn.
Added a tool box on the back.
/ LED Light Bar? #4
Looking good!
That toolbox is Sail Blue isn't it?
/ LED Light Bar? #5
Looking good!
Yes, its sail blue. All I could find at the time. Slightly darker than LS blue.
For those wondering about LED light bars, A couple days ago I was out plowing at 0430 in pitch black. I saw the highway plow truck coming from a half mile away while I was out in the road turning around. When they got up to my house they actually stopped. One of the guys got out of the truck and came over to compliment me on all the lights. From a half mile away they thought there was an accident with the bright lights and flashers and thought I was a tow truck or other emergency vehicle picking up a vehicle since from their view it looked like daylight where I was.
/ LED Light Bar? #6
Thinking about doing the same... swapping all four halogen work lights for LED bars, 8 to 12 inch each. They should be a lower watt than the halogens so I figure I can just use the stock wiring and switches.
/ LED Light Bar? #7
I put two LED's facing forward and two backwards and it has made a huge difference in the usability and enjoyment of working in the dark.
Haven't invested in flashers as I never go near a public road but I like George's setup.
You can for sure use the stock wiring for the rear work light. On my tractor that circuit is 10A if I remember right. All 4 of my lights turned on together are 8A.
There was a spot on my fuse panel labelled "high light" that apparently was spare and not used so I wired my "high" foward/backward lights to that ... that circuit was 15A so I still have room to replace my rear work light with a LED without causing any current problems.
It was funny, I discovered the spare fuze was called "high light" after the fact. I had taken the plastic cover off that said this before I started the project. The manual just says "spare". When I was putting it all back together I put the cover on the fuze box and noticed the "high light" label on it and was like "man, that worked out well".
/ LED Light Bar? #9
I put all this stuff on because I am on the road. I plow out several neighbors.
/ LED Light Bar? #10
The LED amber strobes were cheap. Under $25 for 6 lights with 3 different flash modes
Amber 18 LED Emergency Vehicle Car Strobe Flash Lights Front Grille Truck Yellow | eBay
The 240 LED roof top strobe was also cheap at under $30. I also bought one for my truck.
24 LEDs Light Bar Roof Top Emergency Beacon Warning Flash Strobe Yellow Amber | eBay
/ LED Light Bar? #11
/ LED Light Bar? #12
George, do the switches from this seller fit in the blank spots in your 3037?
The links I provided are the exact products I bought but I didn't buy from those sellers. Many places sell those same devices and I used them as examples.
I don't know if the switches from those sellers fit in the blank spots. I could not find exact fit switches (short of ordering from LS). The ones I bought are exact width switches but are 3/16" short in height. They still snapped in and haven't come out in the past 2 years.
I don't know what they would cost but I'd suggest ordering the right switch from your dealer for an exact fit.
/ LED Light Bar? #13
cford36 - When I did the lightbar install on my XJ2025H. The switches I used were 20 amp dpdt by Carling Technologies. The switches fit the existing 22mm x 44mm cutouts in my dash panel perfectly. I found that most rocker switches sold are for a 22mm x 36mm cutout and I had to search pretty hard to find the correct size for the cutout on mt XJ.
The switches I used are made by Carling Technologies, sealed rocker switches, L- Series. Down load the data sheet at Carling Technologies and use this info to select your switch. You would probably want a single pole switch for your application.
http://www.carlingtech.com/rocker-switches-l-series
I bought the switches at Online Components.com, who is a distributor for Carling Technologies.
/ LED Light Bar? #14
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
MAN BASKET (A64553)
MAN BASKET (A64553)
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64194)
2015 Peterbilt 567...
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
2018 Toyota Camry Passenger Car, VIN # 4T1B11HKXJU524473 (A64557)
2018 Toyota Camry...
