LED Headlight Bulbs T19
/ LED Headlight Bulbs T19 #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
I just found some LED headlight bulbs in a "T19" size, which is the size/type my B2150 uses for the headlight bulbs.
They aren't cheap, but boast 80 watts. Sure seems like it should be much brighter than the oem 15/15 bulbs in it now.
I had tried upping the bulbs to 25/25 watts but they melted the plastic headlight assembly eventually.
I may try them out.... but the seller does not take return so I am torn.
Here is the ebay link:
Yamaha Grizzly 660 Super White LED Headlights Bulb 80W 2002 2003 2004 2005 2006 | eBay
You may have to copy and paste for it to work..... but let me know what you all think.
Thanks.
/ LED Headlight Bulbs T19 #2
I would think that with a little research, you can find them cheaper, and therefore easier to experiment with. I have been looking at auto headlight LED bulbs, which come with drivers, etc., and the prices are even lower at some vendors- usually direct from China, which won't work if you want them in 3 days, but a couple of weeks, no problem. I see lots of choices for LED T-19 bulbs on eBay for around $8 delivered. Let us know how it goes...
Thanks varmint.
I've been looking on ebay and googling for over a week now, and can't locate them anywhere other than a distributor in China who wants a 100-500 minimum order.
I have found other led bulbs on ebay, but nothing that is a T19 like the one I gave a link for.
If you find one, can you post a link?
Thanks !
/ LED Headlight Bulbs T19 #4
My bad. I looked again, with your bulb photo in mind, and came up like you, nada. Now I will be looking, and if I find anything, I'll share. I am surprised that a flange base bulb like that is so rare?
Thanks varmint. I appreciate it.....
/ LED Headlight Bulbs T19 #6
I looked to increase my headlights brightness but in the end bought 2 square led work lights that bolted right on to my rops and hooked to the factory wiring. The lights are higher up so they can light up whether I am plowing or blowing snow. They were on Amazon for about the same price as you are looking to spend for the bulbs....just saying.
Hi sandyc.
Thanks for the suggestion.
I have 4 Rigid Dually LED lights that I do attach to the ROPS. But I have to remove them in the summer due to some nasty low hanging branches on the tree line surrounding my property.
They work very well, but I also wanted to increase my regular headlight output for when I don't have the LED work lights attached.
Regards.
/ LED Headlight Bulbs T19 #8
Thanks varmint.
Thanks !
That is probably what the guy on Ebay did...buy 1000 and started selling them!!:laughing:
You may be on to something there...... That's probably exactly what he did !
It's not so much the $60 bucks for a pair of those bulbs, but he doesn't offer returns in case out to be duds or won't fit properly or whatever.
/ LED Headlight Bulbs T19 #10
Yah, I would just mount some LED work lights... they are widely available, cheap, and work great. I have had good luck with the various ones I have installed over the years.
/ LED Headlight Bulbs T19 #11
Yellowmater,
Thanks ! That's what I was looking for.. Plus, that's the best price I've seen.
I am going to get some and after I install them, I'll report back on the results.
Regards.
/ LED Headlight Bulbs T19 #13
There are also HID kits if you search P15D on ebay.
I've seen the kits, but I wanted something real easy to do. These LED bulbs "should" just pop in the same socket that the old one comes out of........
The oem bulbs (15 watt) are absolutely dismal. The Rigid D2 LED work lights I put on the Roll bar worked pretty well, but I don't keep them mounted all the time.
Trimble True Count Clutch Wiring (A65640)
Trimble True Count...
3147 (A63117)
3147 (A63117)
2022 EZ-GO ELITE...
2011 Blue Bird School Bus (A62613)
2011 Blue Bird...
2003 Kenworth T800 Log Truck (A62679)
2003 Kenworth T800...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
