stoyan79
- Joined
- Sep 21, 2011
- Messages
- 383
- Tractor
- Kubota L3700SU, TYM 4820CH
How can I make thieves job much harder?
Can bring it over I'll watch it,just gotta leave the key in-case need to move it.....
only thing i might addd is replace the fuse you take out with a bad one that fills the hole and they never give it a thought.Others have said it but....
> Take out the main fuse and hide it.
> Leave the PTO engaged.
Unless a thief is tractor-smart the tractor won't start. Not many thieves carry around a fuse.
Then the problem is towing or winching the tractor. If you have a FEL turn the bucket upside down.
If your wheels have a hole in them run a chain through the hole around the tire and around some part of the frame. Chain cutters would defeat this but it slows things down.
I like the "remove a front tire" idea, too. Just hide it somewhere. The upside down bucket can be used to lift the front end enough to remove the tire.
Use the FEL and raise it up and take wheels off and put it on blocks then remove the loader and relocate the loader.
If it has a fuel solenoid wire that's easy to get to, unplug it. Everything will look "normal" but it won't start.
