Leaky bucket cylinder
   / Leaky bucket cylinder #1
joe04785
Maine
XR3037
Hey everyone, just wondering if anybody had hydraulic fluid leaking from there bucket curl cylinders before. I got done snow removal today and noticed on my CK35 that it was leaking. It's not a bad leak yet, but enough to drip on the loader arms. How big of a job is this to do? What is the cost to repack the cylinder?
Thanks
   / Leaky bucket cylinder #2
I blew a cylinder out on my B7800 (popping tire beads from rims- ain't going to do that again!). No slight leaking for me, it was a gusher! :laughing:
When I finally got around to having that cylinder rebuilt it was about $200. I'd bought a new one (time was important) for, I believe, about $700. Thought I'd damaged another one only to find out that I'd spun one of the hose fitting loose (rubbing up against a huge stump- fell in a hole :eek:)
Thanks for the reply. After looking over it numerous times, I decided to put a wrench on the fittings coming out the cylinder. The lower fitting I was able to turn about 1/4 turn or so. I cleaned everything up and so far there is no more leaking. Keeping my fingers crossed that's all it was.
   / Leaky bucket cylinder #4
Just for others -
I had a similar problem. Here.
OP - look around for a good repair facility and get some plugs/caps.
I spent about $10 on caps, $40 for the rebuild in Fulton, Mississippi.
And maybe because I was a stickler on lubing everything came out and went in easily.
   / Leaky bucket cylinder #5
just put seal kit in one on my 1710 with a Koyker 150 loader, did homework prior and some cylinder"s are a little harder than other"s, I bought special tool off ebay for $20. ended up mine did not need it, my cylinder was super easy other than stretching new seal"s on.
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2008 Ford Fusion Sedan (A55853)
2008 Ford Fusion...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Kubota B2301 (A53317)
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
UNUSED SDLANCH SDLL80 LOADER (A57192)
UNUSED SDLANCH...
