Leaking wheel, not tire
/ Leaking wheel, not tire #1
geobar
My Michigan wheel loader has a tubeless tire that will go flat overnight. I put a soap solution all over the tire and inner and outer beads without finding a problem. When I put the soap on the metal rings of the wheel, a big cloud of bubbles quickly appeared. I am not equipped to take this big 20.5 x 25 tire off this 32K lb. machine, but would like advice first on how this wheel is constructed and if something just needs to be tightened, or welded, or what. Thank you.
/ Leaking wheel, not tire #2
you will have to have the tire removed and the rim cleaned up then there are o-rings under most of the locking rings that seal the rim & tire
/ Leaking wheel, not tire #3
Sounds like the perfect application for a tire sealer. It should seal up your leaks and prevent rust/corrosion in the future. Give a good read through this thread on tire sealers. If you have any questions it should answer them.
2005 John Deere 7320 (A60462)
2005 John Deere...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
