leaking rear tire
/ leaking rear tire #1
Crw
Farmall 140
I just bought a new kubota and it seems that I got a small leak in my side wall of one of the rear tires is there a simple fix for this will a plug work and if so do I have to empty the tire they are full of rim guard
/ leaking rear tire #2
If it's brand new, then have the dealer fix it.
I'm pretty sure slugs do not work in sidewalls. Probably you would need to have a tube put in. I have had to do that on a front tire.
/ leaking rear tire #3
i wouldn't plug a sidewall either. a patch from the inside may or may not work depending on the specific cause of the leak.. if too much trouble...i'd tube it, if I had to work on it vs the dealer.
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
2021 ASV 75HD Posi Track Skid Steer (A64047)
2021 ASV 75HD Posi...
SDLE20 Mini Excavator (A64047)
SDLE20 Mini...
80003CFL (A61568)
80003CFL (A61568)
2016 HAMM HDT90IVV DOUBLE DRUM ROLLER (A64279)
2016 HAMM HDT90IVV...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
