Leaking Lines
/ Leaking Lines #1
Mark_G
Va
Kioti CK30 Synchro Shuttle
I acquired a logsplitter that mounts on my tractor from Tractor Supply. I keep having leaks where the hoses connect to the valve. I use thread paste with Teflon as advised and tighten well. The last time I let it dry for days before I used it and it still leaks. I cleaned the threads last time with an alcohol wipe to make sure it would seal well before I applied it. Any advice when I unscrew them yet again, clean them and re-attach?
Thank you,
/ Leaking Lines #2
I had the same issue with mine. I had to tighten them very very tight. I thought I was going to break the fitting but it finally stopped leaking.
/ Leaking Lines #3
If the threads are NPT, they deform to help make a seal. New hoses may be the answer if they have been taken apart a lot of times.
/ Leaking Lines
Thanks all. They were/are new hoses for the splitter. I was afraid to tighten any further. I will see if I can find the locktite.
Mark
/ Leaking Lines #6
Is one end of the hose fittings a swivel?
If not, the pulsing and expansion of the hose can loosen the hose connection.
/ Leaking Lines #7
Are they indeed NPT threads?? or are they o-ring boss fittings that need the o-ring replaced???
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
429858 (A61165)
429858 (A61165)
Kubota KX080-4 (A64126)
Kubota KX080-4...
Kubota Snow plow with subframe
Kubota Snow plow...
1991 BMY 6x6 Wrecker (M936A2) (A62613)
1991 BMY 6x6...
