Leaking Lines
   / Leaking Lines #1
Mark_G
Va
Kioti CK30 Synchro Shuttle
I acquired a logsplitter that mounts on my tractor from Tractor Supply. I keep having leaks where the hoses connect to the valve. I use thread paste with Teflon as advised and tighten well. The last time I let it dry for days before I used it and it still leaks. I cleaned the threads last time with an alcohol wipe to make sure it would seal well before I applied it. Any advice when I unscrew them yet again, clean them and re-attach?
Thank you,
   / Leaking Lines #2
I had the same issue with mine. I had to tighten them very very tight. I thought I was going to break the fitting but it finally stopped leaking.
   / Leaking Lines #3
If the threads are NPT, they deform to help make a seal. New hoses may be the answer if they have been taken apart a lot of times.
   / Leaking Lines
Thanks all. They were/are new hoses for the splitter. I was afraid to tighten any further. I will see if I can find the locktite.
Mark
   / Leaking Lines #6
Is one end of the hose fittings a swivel?
If not, the pulsing and expansion of the hose can loosen the hose connection.
   / Leaking Lines #7
Are they indeed NPT threads?? or are they o-ring boss fittings that need the o-ring replaced???
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
Duetz Power Unit (A50120)
Duetz Power Unit...
KUBOTA ZD1211 (A53084)
Hose Reel (A55758)
Hose Reel (A55758)
SLIDE MASTER ALUMINUM SLIDES (A54757)
SLIDE MASTER...
2017 Ford F-550 Stellar EC5000 2.5 Ton Crane Service Truck (A55788)
2017 Ford F-550...
