Leaking Injector? YM2210
   / Leaking Injector? YM2210 #11
Just an FYI. Chris I replaced my return lines with the small vacuum hose as you described.. It didn't take long for the diesel fuel to swell those lines.. I had to locate some small gasoline rated hose
Agreed. I should have emphasized that the hose has to be fuel-rated.
The hose in the YM186D photo was the remnant left over from a similar refurbishment of my YM240 in late 2003 and its holding up fine there, so NAPA apparently sold me the right grade of hose. I had told the counter clerk it was for fuel.
It was a bit of a search to locate small fuel line, I found 3/16" inside diameter but it looked a bit to big, then I luckily found some 1/8" inside diameter and bought that, I plan to change them out this evening. Hope its a simple as this.
The 1/8" was a bit to small and would not go all the way on the nipple, so I went with 3/16" and it worked, something in between the 2 would have been perfect. But the leak has stopped, the injector bolts were not tight at all, I snugged them up but was unsure how tight to make them, anyone?
   / Leaking Injector? YM2210 #14
i'd just go with tight, not as tight as you could possibly make them but tight with a smaller handled wrench
   / Leaking Injector? YM2210 #15
all those things except the actual steel fuel lines have brass crush washers under them that will deform and take some of the pressure when tightened
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2024 JOHN DEERE 250P EXCAVATOR (A60429)
2024 JOHN DEERE...
