Leaking injection pump
   / Leaking injection pump #1
GDSchafer
John Deere 60
I have New Holland TV-145 an the injection pump has developed a slow drip, does not seem to affect the machine while running but would like to fix it. I am having trouble locating a parts schematic for the injection pump (New Holland part #87802533), from my research it appears to be a Bosch VE6 (0-460-426-340R). I have attached a picture of the pump and where it is leaking. It is leaking where the pump body and what appears to be maybe a manifold block where the injector lines come off? Does anyone have any knowledge of these pumps? There appears to be 4 torx head bolts that hold it on, (I've checked and they're all tight) is there a gasket or possibly an o-ring separating the 2 that might be the cause? I showed a picture to the mechanic at the local New Holland dealer who advised me not to disassemble it and just take the injection pump to a local diesel shop.
   / Leaking injection pump #2
Can you tell if it is leaking Diesel or Oil?
That appears to be a leak between the pump and the block.
   / Leaking injection pump #3
@thepumpguysc
   / Leaking injection pump #4
There is an oring on the head/distributor.
   / Leaking injection pump #5
Yup.. oring is hard and flat..
I’d be happy to fix that for u..
u can contact me directly at:
my screen name at aoldotcom
U can not fix it on the machine.. if u loosen the 4 fasteners, all the guts WILL fall out.!!
There is a nut and washer holding the pump drive shaft to the drive gear.. u access it thru the front.. radiator side..
Chances are hi that it doesn’t have a key in the drive shaft so timing becomes VERY IMPORTANT.. do your homework..
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A48837)
New/Unused 20ft...
Brouwer Hitch-Hiker 3600-R Piggyback Forklift (A49346)
Brouwer...
2015 Hyundai Sonata SE Sedan (A48082)
2015 Hyundai...
Approximately 4,500 Brick Pavers (19 Pallets) (A48837)
Approximately...
2019 RBR Venturi 380 (A50397)
2019 RBR Venturi...
