Leaking injection pump
/ Leaking injection pump #1
GDSchafer
John Deere 60
I have New Holland TV-145 an the injection pump has developed a slow drip, does not seem to affect the machine while running but would like to fix it. I am having trouble locating a parts schematic for the injection pump (New Holland part #87802533), from my research it appears to be a Bosch VE6 (0-460-426-340R). I have attached a picture of the pump and where it is leaking. It is leaking where the pump body and what appears to be maybe a manifold block where the injector lines come off? Does anyone have any knowledge of these pumps? There appears to be 4 torx head bolts that hold it on, (I've checked and they're all tight) is there a gasket or possibly an o-ring separating the 2 that might be the cause? I showed a picture to the mechanic at the local New Holland dealer who advised me not to disassemble it and just take the injection pump to a local diesel shop.
/ Leaking injection pump #2
Can you tell if it is leaking Diesel or Oil?
That appears to be a leak between the pump and the block.
/ Leaking injection pump #3
@thepumpguysc
/ Leaking injection pump #4
There is an oring on the head/distributor.
/ Leaking injection pump #5
Yup.. oring is hard and flat..
I’d be happy to fix that for u..
u can contact me directly at:
my screen name at aoldotcom
U can not fix it on the machine.. if u loosen the 4 fasteners, all the guts WILL fall out.!!
There is a nut and washer holding the pump drive shaft to the drive gear.. u access it thru the front.. radiator side..
Chances are hi that it doesn’t have a key in the drive shaft so timing becomes VERY IMPORTANT.. do your homework..
2019 K&K Equipment Trailer, VIN # 1K9PE2029KA175459 (A65563)
2019 K&K Equipment...
Colombo Twin Master (A64126)
Colombo Twin...
John Deere 6125R (A64126)
John Deere 6125R...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
AGI Westfield WRX 8-61 (A64126)
AGI Westfield WRX...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
