leaking hydrolic fluid from top of transmission cover and thru shifter bases
   / leaking hydrolic fluid from top of transmission cover and thru shifter bases #1
scottwbzz
kennett square, pa
jd 2350
My JD 2350 is leaking a lot of fluid at the base of the cover of the transmission and thru the bases of the geat shifters. How difficult is this to pull the cover and repair?
   / leaking hydrolic fluid from top of transmission cover and thru shifter bases #2
Which transmission do you have? Makes a difference with Hi-Low trans. Cab or open station? Is there a PTO lever on the shift cover?
Not sure which trasmission it is but it does have hi-low. No cab on the tractor and yes there is a PTO lever on the shift cover.
   / leaking hydrolic fluid from top of transmission cover and thru shifter bases #4
With Hi-Low and the PTO lever on the cover there wlll be valves built into the cover. The tubes to these valves come in from the bottom, each will have an O-ring. There will be a retainer plate on the bottom of the cover it will have holes for the tubes with grooves cut for the O-rings.
So you will need a cover gasket and O-ring for each tube. If your shift boots are bad replace them too, major cause of water in the trans/hydrualic fluid.
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54757)
8' SMALL FENCE...
