leaking hydrolic fluid from top of transmission cover and thru shifter bases
   / leaking hydrolic fluid from top of transmission cover and thru shifter bases #1
scottwbzz
kennett square, pa
jd 2350
My JD 2350 is leaking a lot of fluid at the base of the cover of the transmission and thru the bases of the geat shifters. How difficult is this to pull the cover and repair?
   / leaking hydrolic fluid from top of transmission cover and thru shifter bases #2
Which transmission do you have? Makes a difference with Hi-Low trans. Cab or open station? Is there a PTO lever on the shift cover?
Not sure which trasmission it is but it does have hi-low. No cab on the tractor and yes there is a PTO lever on the shift cover.
   / leaking hydrolic fluid from top of transmission cover and thru shifter bases #4
With Hi-Low and the PTO lever on the cover there wlll be valves built into the cover. The tubes to these valves come in from the bottom, each will have an O-ring. There will be a retainer plate on the bottom of the cover it will have holes for the tubes with grooves cut for the O-rings.
So you will need a cover gasket and O-ring for each tube. If your shift boots are bad replace them too, major cause of water in the trans/hydrualic fluid.
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2014 CATERPILLAR 299D SKID STEER (A52705)
2014 CATERPILLAR...
2005 Ford F-750 Truck, VIN # 3FRXF75R05V113199 (A53422)
2005 Ford F-750...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
1827 (A51248)
1827 (A51248)
2002 MACK RD688S ROLLOFF TRUCK (A51406)
2002 MACK RD688S...
