Leaking Hydraulic fittings
/ Leaking Hydraulic fittings #1
Dsh1109
International 484
Hello everybody,
I have an international 484 with some leaking hydraulics. I am absolutely clueless on repairing these and would love some advice. It seems to leak from where the hoses inserts into the fitting, notice how its cleaner around there. What do you guys think I should do??
Thanks in advance!
/ Leaking Hydraulic fittings #2
First thing I'd do is clean that up real good. Spray it down with degreaser and wipe it down and get it CLEAN. Then figure out where the leaks/drips are. If it's a crimp fitting, take the hose somewhere and get a new one or have them make one. It's it's a thread that's leaking, might be able to tighten or apply some pipe dope and reassemble.
/ Leaking Hydraulic fittings #3
Hello everybody,
Thanks in advance!
Do exactly what CH4Ohio said.
If that doesn’t work, I would say your tractor side couplers are probably shot. I have had to replace several of them on my tractors over the years. You can rebuild some of them if you can get the O-rings and seals for them.
/ Leaking Hydraulic fittings #4
Quick disconnects have O-rings in them that can damaged over time. If you have local hydraulic shop remove one of the O-rings and take it there. They should have tools to determine size and potentially have replacements in stock.
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
Crate of Misc Parts (A64119)
Crate of Misc...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
PT Wheel Driven Fertilizer Spreader (A64119)
PT Wheel Driven...
