Leaking Hydraulic Cylinder
/ Leaking Hydraulic Cylinder #1
c3racer2000
I have a Satoh s650g from the early 70's with a National Snow Plow on it. The Hydraulic cylinder is leaking. Do anyone know who rebuilds theses or has a rebuild kit for one? Thanks
/ Leaking Hydraulic Cylinder #2
In all probability your best bet is to simply replace with a new on with perhaps a little modification to adapt.You probably only want a single action one.
Try surplus center (they advertise on TBN) as they have good prices and often 'real deals'.
/ Leaking Hydraulic Cylinder #3
I second Surplus Center.
I get all my Hydraulic hoses,cylinders and valves from them.
Lee
/ Leaking Hydraulic Cylinder #4
We can have most cylinders rebuilt. Even welded cylinders
/ Leaking Hydraulic Cylinder #5
Find a local hydraulic shop and talk to them, take pictures or the cylinder and have them look at it.
/ Leaking Hydraulic Cylinder #6
Agree on rebuilding.....cylinders are very basic in design and I have never seen one that couldn't be rebuilt due to seal failure. Unless you run across a truly smokin' deal on a replacement, I'd even go one step further......take that one apart, take the pieces or just the seals to a local hydraulic shop to match seals or match them up from seals available online and install them yourself. There's real satisfaction in doing it yourself, lots of online info on the subject and you'll know a little more about hydraulics when it's done.
2020 John Deere 6120M (A62180)
2020 John Deere...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
Sterling AT (A63689)
International 806 Wheatland Tractor (A66285)
International 806...
2022 EZ-GO ELITE...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
