leaking front hub, 3520
/ leaking front hub, 3520 #1
docjupa24
lavalette, wv
hi all, i have a leak in the front passenger side hub, pic below, is this just a seal kit, does any one have a part number? any specifics i need to look out for
thanks in advance
/ leaking front hub, 3520 #2
it looks similar to my 4310 which I replaced the front seal
it's easy to replace the seal but you should have a press as one bearing is a press fit
you could take it to a machine shop for the press work
one other question, as long as there is plenty of axle fluid, is it ok to run the tractor till the part comes in, it doesn't seem to leak while rolling, just when stopped
thanks
jp
i finally got the hub off, quick question, do i just take the ring clip off to get to the seal that needs replaced, just thought i'd ask before i get in there
thanks
jp
/ leaking front hub, 3520 #7
thanks
jp
you probably will have to press the shaft out of the inner bearing and slide it out of the flange
the seal will probably be pressed into the flange
the seal may be good , it may be an obstruction keeping it from pressing against the shaft
/ leaking front hub, 3520 #8
thanks
jp
Hi,
What's the year and the hours? there have been extensive threads on this.
Thanks,
Rob
/ leaking front hub, 3520 #9
I do not know what his is but I have a 3320 with 400 hrs on it right now that the needs the front right resealed.
/ leaking front hub, 3520 #10
I think that Deere addressed this to some extent. Are you running 80-90 gear oil or low viscosity hydro? They made some gear changes when they switched andthey might have changed seals too.
What's the year of your machine?
Rob
mine is the 3520, 2005 model,
i had the seal pressed in and no issues so far
thanks for the help, i did find one very detailed thread on this on this site, pics and all, very helpful
JOHN DEERE 4110 TRACTOR (A64280)
JOHN DEERE 4110...
(2) 5' TRAILER RAMPS (A64280)
(2) 5' TRAILER...
4022CFL (A59228)
4022CFL (A59228)
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
20' Reids Trailer (A62613)
20' Reids Trailer...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
