Leaking cylinder?
/ Leaking cylinder? #1
FarmerPhilip
Colorado
Kubota B1550
It appears the hyrdo fluid is leaking from where the white arrows point to on this Kubota la 300 loader cylinder. The circle highlights a drip. It does not appear that a hose or fitting is leaking, checked those first. The highest wet points are where the arrows point. Is this a typical sign the seals need to be replaced/rebuilt? Thank you for your assistance!
/ Leaking cylinder? #2
Yes, just replace seals and it's fine.
/ Leaking cylinder?
Ok, thank you. Didn't want to go down that path without confirmation.
/ Leaking cylinder? #4
had a friend with a case 580 backhoe. he was getting seal weep from a couple rams. he used ATP AT-205 Re-Seal
and after a while the leaks stopped.
/ Leaking cylinder?
Hmm, not a bad idea, I might have considered this a few months ago but it has gotten progressively worse. These days I can follow the drips around and see the trail where I've driver the tractor. Also appears to be a lot worse when I put loads on the FEL. Seems to me like it's just time to rebuild the seals, especially because I don't know the history of the loader. When I get to it, likely not for another couple of weeks given my list of things to do, I'll post pics and stuff.
RoadTec RP190 (A63689)
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2017 Case CX145D (A62177)
2017 Case CX145D...
Gehl RS5-19 (A62177)
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
