gumshu
Platinum Member
- Joined
- Jun 22, 2009
- Messages
- 516
- Tractor
- JD 2025R TLB, Kubota L4802 and Can Am Defender HD7
I have a CT235 and I use it on a hillside. I'm suprised Bobcat did not ship this unit with a no maintenance battery. Battery acid all over the lower grill and battery support plate. It ate through the paint on the lower grill and thebattery support plate. It's easy enough to remove the battery and paint the battery support plate, but removing the grill mesh from the lower plastic frame is not so easy.
The metal grill slides over little plastic posts on the grill frame and is held in place with metal locking clamps that only slide in one way. Removing the clamps from the plastic posts is going to be a trick. Has anyone had experiance with this? Thanks
