Leaking At Front Wheel Bearing
   / Leaking At Front Wheel Bearing
We’re any special tools required? My L2650 leaks on both wheels.
I remember it took me a little bit to figure out how to remove seal, but I did not use any special tool.
I will get to refresh my memory when I take it apart. Will post what I find...
I'm curious if people experiencing these failures are using 3pt ballast and if so, how much weight.
I have loaded tires and have never used ballast box. I do use my loader a lot though
   / Leaking At Front Wheel Bearing #13
I have a 1000 pound 3 point ballast box. It lets me carry full rated loads, but I don’t see how it would prevent seal damage. The weight on the front axle is still there. A rear ballast box may make it worse, as I tend to pick up heavier loads.
   / Leaking At Front Wheel Bearing #14
A tractor is a teeter totter & the rear axle is the pivot. Loaded rear tires make the pivot stay on the ground longer increasing the weight on front axle. Weight on the 3pt lifts the front end decreasing the weight on the axle. If you do loader work wheel or 3pt weight makes it more stable & increases your lift capacity (if not limited by hydraulics). But only 3pt ballast saves your front axle & bearings.
   / Leaking At Front Wheel Bearing #15
Unless the contention is the fulcrum is actually the front axle, not the rear. Then every pound added anywhere can add to the front axle load. Add sufficient weight to the loader bucket and the rear axle will come off the ground.
   / Leaking At Front Wheel Bearing #16
I had a backhoe attachment on mine practically its whole live and they still started leaking around 800 hours. There’s been 100 arguments or probably more about this topic and I’m still calling BS. It would take an insane amount of weight far more than practical to lighten the front end vs none. If you said you’re saving the front end by increasing the traction on the rear and reducing the work the front 4x4 does you’d be right or if you said the tractor was a lot better with more ballast added you’d be right but reducing the front axel load by adding more weight isn’t happening.
   / Leaking At Front Wheel Bearing #17
My L2650 has had a box blade and front end loader on it most of its years. Back tires are water-filled. I have been known to use the loader for moving weight I probably shouldn’t be. No separate ballast. 1200 hours and this will be the second set of seals, the last ones done by the dealer. I still think it was a design flaw as almost everyone I know has the L2350, L2650 and L2950 has had the leaky seals. If I don’t need any compression or specialty tools I may try this myself.
   / Leaking At Front Wheel Bearing #18
I've had the front come up when the rear is too heavy (dirt in BH bucket while on an up slope) and I've had the rear come up when the front is too heavy (load in FEL on level ground). I know my left front is leaking and I think the right is now too. Not sure yet, but hope it's just seals. I've moved an awful lot of gravel in the FEL, nearly all with rear weight added.
   / Leaking At Front Wheel Bearing #19
Right front on my Yanmar at around 1800hrs. I do a lot of FEL loader works at well, moving logs, saw mill slabs, lumber. Bearing retainer went, eating up seal. Fairly straight forward repair. $100 something in parts/fluid and couple hours. I did use a hydraulic press on the bearing (7) to press it into the case (1) and the spindle (3).
enhance
enhance
enhance
enhance
Left side began leaking couple months later. Ordered the same round of parts, and replaced while in there, but couldn't really find anything like the right side bearing. I DID remove a tight wound wad of round bale net wrap that had worked it's way around the hub shaft and I suspect into the seal, causing it to leak......
enhance
   / Leaking At Front Wheel Bearing #20
I was charged $350 for both front repairs. After over 9 years of heavy lifting, I thought that was a fair price. And best part...I didn’t have to,do it
207273 (A52708)
207273 (A52708)
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
3Pt Aerway (A59814)
3Pt Aerway (A59814)
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
