Leaking around pto shaft
   / Leaking around pto shaft #1
budepps3760
Montgomery, Al
Mahindra 2810
Today I changed my transmission/hydraulic fluid for its scheduled maintenance. Proceeded to bush hog for about 30 minutes. After pulling it into the shed I noticed that there was fluid leaking from around the pto shaft. Well darn. What am I looking at folks as far as repairs? Major? Complicated? Expensive? I have a Mahindra 2810 with 613 hours on it. Earlier this year I spent $1,200 on the steering cylinder replacement due to operator stupidity.
   / Leaking around pto shaft #2
That seal should be replaceable without splitting the transmission. It was on my Kubota B7100. On that I didn't even need to unbolt a cover, just carefully pry out the old seal and install the new one.
It may be a coincidence that the seal failed right after an oil change but if it was me I'd double check the oil amount and type.
   / Leaking around pto shaft #3
Seal failed after bush hogging, not after oil change...so that gives me the impression (although ericm979 could be right) that most likely you picked up a long piece of grass or otherwise that wrapped itself around the pto shaft and got eaten by the seal. Sometimes you can VERY CAREFULLY pop the seal edge up to see if there is grass wrapped around the shaft, and use a pick to remove it (an L shaped pick works good). Worse case, you mess up the seal if it wasn't already damaged. Double check the shaft where the seal rides to make sure you don't have a groove, but not likely in 30 minutes of mowing.
David from jax
Thanks for the suggestions gentlemen
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2014 Ford Escape (A50323)
2014 Ford Escape...
Unused Delta Crash...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2008 JLG SKYPOWER 800AJ MANLIFT (A51246)
2008 JLG SKYPOWER...
