Leaf vac
/ Leaf vac #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I been trying to search for info on a pull behind leaf vac system and keep getting no results (tried leaf, vac, D&R, DR, yard, clean up, etc..) so I have to ask...
What is a GOOD pull behind vac system? I have about 3 acres where I am going to want to pick up leaves and would like that option of a long hose to suck out the flower beds and around the pond. I have a Kubota 7610 and would like to hook it to my 60" MMM and prefer that it does not run on the PTO of the tractor (that way I can pull it outher place with the atv and pick up leaves"
Makes, prices and quality all are of interest.
Thank you in advance!
/ Leaf vac #2
Try leaf grass vacuum. http://www.drleafvac.com , http://www.cyclonerake.com , http://www.trac-vac.com . The last one has the most different models.
Monte
/ Leaf vac #3
I happen to have a B7610 and an AgriFab 8hp Chipper/Lawn Vac. I can tell you this much, and I suspect it will be an issue with all pull-behind Lawn Vacs, the deck-to-vac discharge hose is too short to use with my 7610. The Lawn Vacs are typically pulled with smaller lawn tractors (I use a 48" JD GT275) and the discharge hose designed and sized accordingly. I suppose you could always purchase extra hose length but I would be wary of clogging up a longer hose with the low hp model vacs. Probably have to keep your ground speed in check too, that RCK60 deck would be doing a whole lotta collecting...
/ Leaf vac
Thanks for the info. The thought about the hose lenght makes good sense and I never thought of it!
Has anyone used the Kubota one or any these to render an opinion. The DR looks nice for the chipper but a bit $$$$, the trac vac looks like a nice one too but I really have no idea.
Thanks
/ Leaf vac #5
Buy a Trac Vac. I have had two a 580 that I used with a Wheel Horse 520 and then with a Kubota B2400 . With the Kubota I Found That the 54 inch Deck discharged to many clippings for the 6 inch hose . Don't get me wrong , it worked used it several years picking up about 4 acres about 900 bushels of leaves a year with it. But the ideal vac for that size deck is a 880 or what I have now a 1080 Because they have more horsepower and the discharge hose is 8 inch diameter. I have a new holland TC 33 DA that I Use with the 1080 it's great I also have A smaller version that Hangs on My three point That I use for Grass clipppings. Trac Vacs are expensive < But they are built well and they last.
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
(4) 10-16.5 Tires (A65640)
(4) 10-16.5 Tires...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
(4) 17in. Honda Rims (A65640)
(4) 17in. Honda...
