LB1914 glow plug light
/ LB1914 glow plug light #1
fyrman1
The glow plug light on my tractor is not coming on and the tractor wont start. Engine turns over but wont start. what should i be checking out and how? it has 185 hours and is about 9 years old. thanks.
/ LB1914 glow plug light #2
Does your's have a "light", or the glowing "pig tail" wire in a viewing port? If it's the latter, more than likely the wire has burned through or broken and "0" current is going to the glow-plugs. You can by-pass the indicator with a jumper wire to the glowplugs, but only momentarily as the wire is also used as a resistor
Thanks, its a pigtail. I never would have thought of that one. I will check it if i can get home before dark. thanks again.
John Deere 302A 50HP Front Loader Utility Tractor (A61572)
John Deere 302A...
UNUSED WOLVERINE QUICK COUPLER 1 (A64281)
UNUSED WOLVERINE...
2022 John Deere 5055E (A62177)
2022 John Deere...
2003 Ford Ranger Pickup Truck (A61573)
2003 Ford Ranger...
Dodge 5500 Bucket Truck (A63688)
Dodge 5500 Bucket...
Utility Cart (A59231)
