Lawn sweeper
/ Lawn sweeper #1
Blade Breaker
Southern MN
5115M, 825I S.E., 1445 S2, F932, M, H, 8N,
Hi,
I have a agrifab 44 inch sweeper. Products > 44" Lawn Sweeper
It works well but I would love to have one that is 6 or 7 feet wide. Anyone know of any that are made this wide?
Thanks
/ Lawn sweeper #2
I've been looking for a sweeper that is between 60" and 72"...so far, no luck.
/ Lawn sweeper #3
It would probably be expensive to do so, but you could fabricate something like this from three narrow sweepers.
Parker Turf Sweeper 100" Estate Master 3 Pull Behind 89580100
Steve
/ Lawn sweeper
Wow three of them. That would go quick but may be a bit of a hassle. Sounds like there are not any options for a wider single sweeper. I can understand that I guess. Was just sweeping wet clippings now and it gets heavy to unload. If wider and heavier a different unload method may be required.
/ Lawn sweeper #5
How much do you want to spend?
How about one of those gas powered vac trailers, then fab up a wide intake on the front of it?
/ Lawn sweeper
Yes that would work but then another engine to maintain. I really like the simplicity of the sweeper. Also the sweeper does not get everything like the vacuum would. I never fertilize my lawn but try to leave some clippings. I just like to get the clumps and thick piles. Has work well for many years.
/ Lawn sweeper #7
I think mine is 5 years old and is a 42" and it really doesn't do very well on grass clippings and I've about wore it out dragging it around. I've adjusted the height all over the place. JUST Doesn't work very well. NO more lawn sweepers for me. bjr
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
ALLMAND ECO-LED LIGHT PLANT (A68842)
ALLMAND ECO-LED...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
1998 Freightliner MT45 Step Van Food Truck (A66736)
1998 Freightliner...
