Not sure this is the best forum but will give it a shot.
Have an MTD commercial 60" walk behind mower. The set up has the 17HP Kawasaki engine that drives a pump that feeds fluid to the drive pumps/hubs at each wheel.
I noticed toward the end of the season that one drive wheel would not turn as fast as the other. Even having the throttle on that drive pump/hub full open it was still going slow but then after a couple of minutes it would start operating normal and then run fine.
Entire hydraulic system was drained, refilled & new filter in the spring and ran fine for 4-5 months.
Would like to get some thoughts on what might be the issue so I can look into this before spring!
