Last 2 questions about JD HPX4x4
   / Last 2 questions about JD HPX4x4 #11
oh and about the lift kit . don't get it i made mine from hardware store parts for 5.55 cents. and it's the same thing. i'll tell you what you need if you want to make it yourself.. it consist of two pipe nipples with the o.d of almost 1 3/4 inches and 4 flat washers with the o.d of precisly 1 3/4 one washer . jackup the front and loosen the two bolts holding the shock in and the shock will drop out the insert one 1 3/4 flat washer then insert a nipple and then put the second washer on top then drop in the shock and tighten up the two bolts repeat it on the other side and walla you just lifted the front 2 ''. and it takes about 35 minutes to do.
   / Last 2 questions about JD HPX4x4 #12
More info coming soon! (A55787)
More info coming...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A55852)
2022 Chevrolet...
2006 International 4300 2,000 Gallon Fuel Truck (A55852)
2006 International...
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
EZ-GO Electric Utility Cart (A55851)
EZ-GO Electric...
Cushman Electric Golf Cart (A55853)
Cushman Electric...
