Last 2 questions about JD HPX4x4
   / Last 2 questions about JD HPX4x4 #11
oh and about the lift kit . don't get it i made mine from hardware store parts for 5.55 cents. and it's the same thing. i'll tell you what you need if you want to make it yourself.. it consist of two pipe nipples with the o.d of almost 1 3/4 inches and 4 flat washers with the o.d of precisly 1 3/4 one washer . jackup the front and loosen the two bolts holding the shock in and the shock will drop out the insert one 1 3/4 flat washer then insert a nipple and then put the second washer on top then drop in the shock and tighten up the two bolts repeat it on the other side and walla you just lifted the front 2 ''. and it takes about 35 minutes to do.
   / Last 2 questions about JD HPX4x4 #12
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2011 Audi Sedan (A56859)
2011 Audi Sedan...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
2024 BOBCAT E60 R2 SERIES EXCAVATOR (A52707)
2024 BOBCAT E60 R2...
