Laser Burning Question
   / Laser Burning Question #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
I don't know any machinist forums to post this too so here goes.
Anybody had any experience with burning 5/8" tap drill holes in 1/2" plate steel with a NC Laser. Does the material in the heat zone micro harden so as to make tapping very impractical? I can have it burned slightly under and then run a drill through but it will drive the labor cost sky high.
   / Laser Burning Question #2
How 'bout waterjet instead. It's not as precise but you have no heat affected zone.
   / Laser Burning Question #3
Might give Barrry a call here. He is a great guy, and very, very familiar with lasers etc. There are a couple laser specific forums as well, although I am not familiar with them.
Introduction
   / Laser Burning Question #4
I was not aware that laser cutting was availabe for plate that thick.
In my experience it has be limited to thin gauges.
Most "patern places" (custom machine shops) use a water jet in these parts. The precision on water jet should be sufficent for a tap operation depending on required % threads.
   / Laser Burning Question #6
Afternoon shaley,
If the material is CRS plate low carbon there should be no problem laser cutting the plate. Obviously you need a machine that can handle 1/2" plate but not a problem ! There should be no hardening issues so therefore no tapping issues either !
If you are trying to do the same thing on alloy material then you potentailly can have problems !
As the others have suggested, waterjet is a viable option also, but not as accurate as laser. I have been a toolmaker the past 35 years but most all of that type work we subcontarct. Hope this helps answer you question.;)
Thanks Guys,
I'm trying to make some wheel adapters out of A36 PL. If I can keep the machining to just one machine operation it will keep my cost down. The Laser company I spoke with says 1" max for there machine.
   / Laser Burning Question #8
Waterjet is the way to go. At work we have used it on 1" nickel chrome plate which is very hard to machine and it did a very good job.
   / Laser Burning Question #9
Shalley
I used to do some computer work for a company that did waterjetting. They would rough cut parts to within .01 in. and then send the parts out for finish machining. When I moved they were upgrading to what they hoped would be .001 in accuracy. Would that be accurate enough?
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
