Laser Burning Question
   / Laser Burning Question #12
shaley said:
I don't know any machinist forums to post this too so here goes.
Anybody had any experience with burning 5/8" tap drill holes in 1/2" plate steel with a NC Laser. Does the material in the heat zone micro harden so as to make tapping very impractical? I can have it burned slightly under and then run a drill through but it will drive the labor cost sky high.
Depends on how many holes you expect from each tap. If this is going to be an ongoing production process, I don't think it would be practical. If you're going to tap a few holes and then you're done, it could work. If you keep a CO2, Argon, or nitrogen blanket on it while it's burning, you can avoid some of the abrasive scale.
   / Laser Burning Question #13
I've been in the laser cutting business for awhile.
I'd say with 1/2 inch plate and 5/8 holes, which is about M14 in metric, the cut will be rough. Lasers cut rough due to the heat put into the material when cutting holes with the same diameter as the plate thickness.
Are you talking lots and lots of holes ? Then either use the laser to precisely engrave the center of the hole and then drill and tap (and save on laser time because spouting a start hole costs as much time as making a 2 feet cut) or laser a hole that is 2mm smaller than what needs to be tapped, and use a tap drill. I dont know if you can get them in that size, or in imperial sizes, but it is a tap with a drill up front. we used them all the time.
   / Laser Burning Question #14
I am wondering if this is a couple of wheel adapter's for his tractor or is he fixing to start a manufacturing line of them?
If just a couple, heck mark them out, send them to me and I will drill and tap them. If your starting a business, I am not the one you need to talk to.
David from jax
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
MILITARY  BED TRUCK (A58214)
MILITARY BED...
