Largest JD Tractor With Autoconnect Deck
   / Largest JD Tractor With Autoconnect Deck #1
dieselscout80
Veteran Member
South Carolina
New Holland TC45DA
What is the largest JD tractor that uses the Autoconnect Deck?
Is there anything larger than the 3720 in the pre-emission tractors?
I’d like to have a little over 40 PTO HP as a minimum?
So is the 3720 the largest JD that has the auto connect deck?
   / Largest JD Tractor With Autoconnect Deck #3
Which model did your John Deere dealer say was the largest one???
SR
I’m looking for used tractors not new.
The 3720 is the largest I have found, so far.
   / Largest JD Tractor With Autoconnect Deck #5
I'm not sure it is offered on anything above the 3 Series but a dealer would know for sure. You probably aren't getting many responses because most people that move above the 2 Series are mowing many acres of grass with a larger tractor and they use a large 3ph mower. They then use something smaller to mow the grass right around the house. The 3ph mowers tend to be less than the autoconnect MMM and are larger. I mean for the price of the 72" autoconnect deck you can get a pretty good z-turn for mowing right up next to the house and around obstacles. Just something to think about....
   / Largest JD Tractor With Autoconnect Deck #7
From what I can find, the 3720 is the largest pre-emission unit that is compatible with the 72D deck.
It looks like anything bigger than the 3720 (pre or post-emission) will require a rotary cutter out back on the three point.
   / Largest JD Tractor With Autoconnect Deck #8
Auto connect was released in 2008 (I believe), the 3x20 series was the largest tractor to accept a auto connect deck. 4x20's could still take decks, just not auto connect.
   / Largest JD Tractor With Autoconnect Deck #10
That would make for a rider on steroids!
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-150...
AGT QH12 Mini Excavator (A50322)
AGT QH12 Mini...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52748)
2022 Down2Earth...
