Larger HST tractor(s)
/ Larger HST tractor(s) #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Is the Kubota L5030HSTC the largest hydo cab tractor?
I know the larger TLB (Case, Volvo, John Deere) are fluid drive. But I need the 3pt hitch. with a FEL.
Thanks
/ Larger HST tractor(s) #2
Check out.Fendt
They don't have a hydro as such, but they are the oldest in the industry with a non shifting transmission with he CVT. Like the hydro, you just push and go.
/ Larger HST tractor(s) #3
If you want to go with the IVT then you have options all the way up from the John Deere 6420 series. Instead of pedals you have a little lever on the console to the side that controls the gear ratios infinitely. My 8320 has this and it is very nice. You have the toughness and no loss of power with the gear type transmission but the luxury of variable speeds without shifting. This is especially useful with the GPS.
A true hydro I believe you are right about the kubota being the biggest true hydro. If you want to wait rumor is JD is coming out with hydro in their utility line in the next couple years.
/ Larger HST tractor(s) #4
Renault has the Ergos line that is hydro,up to 85 hp I think it is. Renaults are presently sold in Quebec,and in the future we will be seeing them as Claas tractors in North America.
/ Larger HST tractor(s) #5
NEWHOLAND HAS A BI DIRECTIONAL TRACTOR
about 150 HP with loader and 3 point hitch on both ends
Do the CVT and IVT transmisions allow for direction changing without using the clutch and under load?
Can a true hydraulic shuttle shift transmssions (power reverser, GST, etc.) do direction changes without clucthing and under load?
/ Larger HST tractor(s) #8
On Deere yes you can change directions without the clutch on IVT and power reverser transmissions.
/ Larger HST tractor(s) #10
It's 105 PTO HP. You can check it out here. I saw one on the dealer's lot. Pretty interesting setup. That is one big front/back?? end loader.
Freightliner Columbia (A63689)
Freightliner...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2) 30'  42" High Pipe Racks (A62679)
2) 30' 42" High...
2005 INTERNATIONAL 9400I (A65643)
2005 INTERNATIONAL...
2018 VOLVO VNL 670 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 670...
