Larger Battery for UTV??
/ Larger Battery for UTV?? #22
Just FWIW, although I would replace a dead battery with a bigger one, I wouldn't replace a good battery with a bigger one.
I have the Polaris ranger diesel with front and rear winches. I have used both together pulling things out (tractor out of a ditch etc). I also have various light bars on it (but no stereo :). It gets used several times a day, a lot of short distance (less than 1 mile) start/stopping.
It is still on its original battery from 2011. Winches use surprisingly little power, especially these small ones. As long as it's running and the alternator is charging (you can hear it load the engine), a bigger battery won't really do anything for you.
/ Larger Battery for UTV?? #23
I've set up about 6 ATVs and UTVs over the year's all for work at night with extra lights and power hungry systems added. Never put and extra battery in any of them and our boss 6x6 was the only one that gave us low battery greif.
/ Larger Battery for UTV?? #25
I have the Kubota diesel RTV. I plug into the acc. port to power my fuel station pump, keeping the engine running. If I’m just fueling the RTV, the wire behind the plug gets pretty hot. But when I fuel both the RTV and the tractor, it often pops the RTV’s fuse. Will a bigger battery keep this from happening?
/ Larger Battery for UTV?? #26
There are reasons why a wire gets hot. A small battery is not the issue.
Most likely, the wire is too small in diameter, too long or both creating more resistance thus the heat. This is not a normal or safe situation, especially where a fire can break out while fueling. It might be a good idea to get an electrician involved or at least post a new thread on this forum with the pump information, what you are trying to do and how long the plug is. good luck
/ Larger Battery for UTV?? #27
I have a Kubota DIESEL UTV. No problems but just added a Winch. I know that a winch draws alot of powerr. The battery box (under and behind driver) seems large and I was wondering....hmmm...could I install a larger battery? Suggestions? Thanks
I’m curious, did you direct connect to the battery? I did the same but I added a fuse block and ran mine through it. Problem is it will blow a 40 amp fuse if it gets very much load on the winch. I may have to move power directly to battery or put a inline fuse in that can accommodate a 50-60 amp fuse. Thoughts?
/ Larger Battery for UTV?? #28
The purpose of the fuse is to blow if there is excessive resistance that could become dangerous. Better the fuse than catching fire.
Putting in a higher fuse is literally making it worse.
I don't know the size of the motor but I would be surprised that anything over 15 amp on a SXS is worth getting some expert help.
For reference, my entire RV 30 amp fuse will flip off if I am using the microwave+ big A/C unit+anything else.
If you are blowing a 40 amp fuse you are pulling energy to run my entire RV system is rated for.
/ Larger Battery for UTV?? #29
Thanks, Root Cause, for your thoughts on the fueling power. Didn't mean to commandeer Boeing's thread. I'll do as you suggested. First off, the wire is way longer than it needs to be...
/ Larger Battery for UTV?? #30
My apologies as well to the Op but in this case, worthwhile. Good luck and be safe.
/ Larger Battery for UTV?? #31
Even a small winch will pull a LOT of amps under full load. For example, the Harbor Freight Badlands ZXR 2500# winch pulls 132 amps at full load.
/ Larger Battery for UTV?? #32
DO NOT put in a larger fuse -you may burn your wiring harness out of the machine. The lighter port/ ACC. Port is not made for the high current draw. If you look at larger quality onboard compressors for SxS/.Jeeps, they all have clamps for the battery and ditch the lighter port because of the amp draw. Same with a winch, they don't have lighter port plugs due to their current draw. Someone mentioned winches use surprisingly little power, but that is incorrect - they are one of the highest draw items on an SxS (for example, a 4000lbs Superwinch at 4000lbs pull is pulling 210amps - WAY more than a average factory SxS is producing). For example, A X3 Can-Am is putting out about 45 amps at 6000 RPM, Even a KRX1000, if you add an Alternator kit from the factory you only gain 60 more amps - still keeping you way below the 200 amps you need if you are winch yourself up a rock face. Thus why some of us run 2nd batteries - we need the cold cranking amps in reserve for heavy winching or in some cases guys need it to power their stereos and subwoofers as they suck some series power.
/ Larger Battery for UTV?? #33
IF you have high current draw (amperage) devices one should add fuse block and fuse direct from battery using appropriate gauge wire...IF wire gets hot its tell you its to small of a gauge and the resistant in small gauge is to much for large amperage draw.... IF it blows fuse on internal circuitry that means current draw of device is more than electrical system is designed to handle, bugger fuse will only cause you more grief if internal wiring goes up in smoke...
My tractor has wired in a accessory power port limited to about 10 amps, got to respect that because tractor wire harness is to "light" to handle any thing bigger.....
IF I were to add a winch, first I would look at wire gauge on winch, THEN add system on tractor directly from battery with wire gauge that is same as on winch or recommended in winch manual (if wire not included)... Same goes for any device other the afore mentioned winch...
2007 Ford F-150 Pickup Truck (A64194)
2007 Ford F-150...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2018 Tycrop Vector Belt 22ft. VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2018 JOHN DEERE 1023E SUB-COMPACT TRACTOR (A67148)
2018 JOHN DEERE...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
